Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Thread Tools
Old 2nd October 2021, 09:41 PM   #341
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Retro - A fully symetrical phono stage with RIAA filter
Countersink the screws in the chassis lid and base to remove some anodizing for a better contact and full case continuity. I have to do this with modushop cases. Sometimes it helps.
Worth checking the rega grounding, the arms used to be grounded through one of the negative cart pins.
Old 3rd October 2021, 01:00 AM   #342
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Check for continuity between your two cartridge wires and the turntable chassis. They should be completely isolated.
Old 3rd October 2021, 02:58 PM   #343
thematikma is offline thematikma
Thanks for your replies, guys!
Try lifting that ground. Hum is usually caused by ground currents.
I did mod my rega deck with a separated ground wire. The cart and arm have no contact to the signal wires. Lifting or connecting the ground, makes no difference. So I leave the cart floating for now. I am planning to rewire the arm to XLR in the near future anyway.
Anodizing is removed for the connection of pin 1 to the case panel. On all other grounding screws, I used toothed washers (connected the case parts to each other).
Funny enough, when I place the case 90 sideways, the hum disappears. I accept that as a solution for now. But I really suspect the rega plugs or cables the culprit, picking up ac mains radiation.
Can you make a drawing of your audio connections, ground connections, and earthing to the wall sockets?
No connection to mains safety earth, as I use USB for power input. But I did try a wire from the case of earthed equipment to the Retro case, with no difference.
Old 5th October 2021, 03:25 AM   #344
The outputs of your cartridge will be a balanced signal, which means it is possible to eliminate any interference if it is wired correctly. Ideally, both + and - singla s shoudl be exposed to the same interference, so that it can be cancelled out by the input section of the Retro.
If your balanced signals are running through standard shielded RCA lead, one of the signals it the shield, the other the center conductor. This arrangement will result in the shield signal receiving the bulk of the interference, and will result in noise, as the cancellation will be ineffective.
I recommend you ground the chassis of the turntable to the chassis of the pre-amp, as well as the mains earth to the chassis of the pre-amp. These should all tie to the same location in the pre-amp, close as possible to the mains input.
Whether you connect the audio signal ground to the chassis ground, as well as how you connect it will depend heavily on your particular configuration.
I am curious about your power source. It comes from the USB input?
There may also be a ground loop at play here, but it is hard to say, and the noise would not vary with placement, but it could be a secondary issue.
[NOTE: Just saw your internal pics above. Let me look at those for a bit.]
Old 5th October 2021, 03:31 AM   #345
The only other thing I can see in that picture is that I would avoid "daisy-chaining" power from one board to the other. Ideally you would run each board directly to the power supply. I have seen this be an issue in the past.
Old 6th October 2021, 09:37 PM   #346
Brian,
thanks for taking a look at my problem!
Yes, unfortunately the tonearm cables are standard rca, leading the green and blue leads through each shield.
The turntable chassis is made out of dense foam, but I did try to ground the housing for the bearing and a motor case screw to the Retro chassis, with no luck. In addition another wire from the PE terminal of an outlet. Everything not better, nor worse.
For the power supply I use Jans/Linear Audio "Silent Switcher".
A USB keystone in Neutrik D type panel fitting is also isolating the 5V, gnd and shell from the case. For the 5V input I use a powerbank.
My other option is a AMB sigma22 I may also try, if swapping the turntable leads does not help.
I will get rid of the daisy chain power routing next thing, thanks for the hint.
  Reply to this post
Retro - A fully symetrical phono stage with RIAA filterHide this!Advertise here!
Thread Tools
RIAA Phono Amp Design Sheldon Tubes / Valves 58 26th August 2019 04:07 PM
how build usb phono pre riaa tekton364 Analogue Source 2 28th September 2007 09:50 PM
WTB: RIAA Phono Stage mrdon Swap Meet 1 19th July 2007 05:00 AM
RIAA phono stage KevinTams Tubes / Valves 10 16th May 2005 02:05 PM
ls-37 MM/MC RIAA Phono Amp from diyclub.biz wuffer Tubes / Valves 2 13th November 2004 05:12 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
