Go Back   Home > Forums > > >
Twin Audio Twin Audio is a manufacturer of hand made audiophile tube amplifiers.
Thread Tools
Old 18th October 2021, 04:54 PM   #61
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Markaudio New Full Range Driver Alpair 5 Gen.2
70 litres, what tuning?
dave
Stay safe. Stay home. Respect the 2m bubble.
Old 18th October 2021, 08:08 PM   #62
superlian is offline superlian  Norway
Ř11 cm x 17cm port
I think 40 Hz?
Outside dimension 800 x 450 x 310 mm
Old 19th October 2021, 01:24 AM   #63
frugal-phile(tm)
planet10's Avatar
Yes, working backwards from the vent size, 40 Hz.
Not pretty IMO. Other curve is sealed Q=0.5
Markaudio New Full Range Driver Alpair 5 Gen.2-jbk-2206-70l-sim-png
dave
Old 19th October 2021, 07:15 AM   #64
Maybe dsp and 4 channel amplifier is better?
Old 19th October 2021, 07:18 AM   #65
dave
My simulation with winisd, 70 liter & 40 Hz was like this:
Old 19th October 2021, 05:15 PM   #66
frugal-phile(tm)
planet10's Avatar
That is quite different.
dave
Old 20th October 2021, 10:01 AM   #67
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
I'm up to my eyeballs writing a paper, but briefly, as Dave asked me to take a look at this, I suspect we're looking at variations in the modelling basis. All the basic modellers should be running the same baseline maths, but they tend to show some shifts when you incorporate other assumptions (e.g. damping, box leakage, port frictional losses etc.) even if you adjust the coefficients to nominally the same.
Attached; this is with the published data & 0.5ohm series R added for wire loop, connection resistance. All boxes of the same Vb & Fb.
Top left & centre = a modified variation of MJK (which from long experience I know to be reliable), with the dimensions stated above adjusted for internal, and the equivalent of about Qa = 40 lagging.
Bottom = Unibox, which is usually consistent with MathCAD and I usually find consistently reliable to measured.
Top right is BassBox6pro, which has some qualities, but I tend to find sometimes shows some variation in alignment terms with the same specified nominal dimensions, tuning, damping, leakage etc. YMMV. In this case, it appears closest to the WinISD alignment indicated in the post[s] above, whereas my modified version of MJK and Unibox are closer to Dave's, although adjusting for the different graph scales, in fairness overall they aren't all that far apart.
www.wodendesign.com (commercial site)
www.frugal-horn.com www.frugal-phile.com (community sites)
Old 20th October 2021, 04:04 PM   #68
The idea with this tuning is to use the room gain as a «friend» in ordinary Norwegian Living rooms aka Amercian bedrooms
  Reply to this post
Markaudio New Full Range Driver Alpair 5 Gen.2Hide this!Advertise here!
Thread Tools
Markaudio Alpair-6P Paper Cone 3.5" Fullrange Gen 2 xecluded Full Range 11 6th December 2015 11:20 PM
WTB Markaudio CHR 70 (Gen. 3) or Alpair 7.3 Qbert25 Swap Meet 1 19th October 2013 12:34 AM
Need help with matching MarkAudio Alpair 7 gen 2 golgiapparatus Multi-Way 6 21st May 2012 03:27 AM
FS: MarkAudio Alpair 10.2 Full-Range drivers nar93da Swap Meet 4 7th August 2011 10:36 PM
Initial Impressions: Alpair 12 full-range driver by Mark Fenlon drspence Full Range 81 19th June 2010 08:28 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
