noisy noisy noisy noisy noisy tube
Old 14th February 2006, 10:08 PM   #41
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
It is the weirdest thing because I have an old Melos SHA that makes the exact same noise in the exact same way. I have never figured out what it is there, though I haven't tried very hard either. I always figured, based on age and the amount of corrosion on the circuit board, that it was a leaky something.
Anyhow, for grounding, just so I know what I am doing, each power suppy currently has what might pass as a star ground. The high voltage center tap and the negative side of all three power supply caps all connect to a point. Is it reasonable to now conect the bass of the cathode resistor/cap as well as the ground connection for the CCS to this same point? Do I also connect input and output grounds to this point? This will leave me with 2 stars. Would I then connect them together?
Also, I currently have the main's earth connected to the chassis and the circuit ground also connected to the chassis in the same spot. There don't sem to be any ground loops, so should I keep this basic setup?
Old 14th February 2006, 10:17 PM   #42
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
One 0V star for all the supplies. Incoming mains earth directly to the chassis. 0V star positioned as close as possible to the input stage with really short wires from the grid and cathode. Bond 0V star to chassis with really short wire (certainly <2").
Earth loops: Only one bond from 0V to chassis. make the bond at the input of the most sensitive audio amplifier (usually RIAA stage).
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 14th February 2006, 11:10 PM   #43
dsavitsk's Avatar
This is kind of how it is already. As I said, each PS has a star. Each of these is connected to the terminal strip next to the tube. Each cathode is also connected to this point as are the input and output grounds.
There are some wires going through the air to get there, but other than tidying things, I am not sure what to change?
Old 19th February 2006, 06:53 PM   #44
dsavitsk's Avatar
Some updates, I did some work on the ground with no change.
More importantly, I pulled out the bottlehead CCS and replaced it with a LM317 based CCS. The tubes are still noisy, but now it is a loud hiss (and terrible bass where the pre used to be quite punchy.) Any suggestions?
Old 19th February 2006, 08:05 PM   #45
On Hiatus
SY's Avatar
I'll bet the 317 is oscillating.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 19th February 2006, 08:36 PM   #46
SemperFi is offline SemperFi  Wake Island
I have had several low power guitar amps with the kind of noise you are mentioning. On every one of them the cure was to bias the heater to some positive voltage, say +20 to +40volts. Dead quiet after that.
Try connecting the heater transformer center tap to one of the cathode resistors and see if it helps. For some reason I always use a series resistor when connecting the heater to anything but ground, but really don't think that's necessary.
Old 19th February 2006, 09:36 PM   #47
dsavitsk's Avatar
I think that's right. I replaced the original ccs with a different one to see if this might be the problem.
Anyhow, I added a 100uF cap in parallel with the CCS (I think there was an earlier suggestion to do something similar to this) and while the hissing is gone, there is still a little bit of hum, and more importantrly, I seem to have made a low pass filter around a couple hundred Hz. So, I now have a muffled and quiet and bass only pre. Is there a better way to get rid of oscillations, or a different size cap to use?
I tried the heater biasing as well but it didn't do anything.
Old 20th February 2006, 12:56 AM   #48
On Hiatus
SY's Avatar
Have you tried a bipolar cascode?
Old 20th February 2006, 05:34 AM   #49
dsavitsk's Avatar
I've not. I am not sure what it is exactly, other than another CCS, or why it might be beneficial. Is the game here to keep trying different CCSes until one of them doesn't oscillate? I'd rather not do that. I really only tried the LM317 to see if the noise was in the tube, or due to oscillation. Now that I know it to bein the CCS, my strong preference would be to go back to the bottlehead CCS and get it under control somehow. What I really don't know, however, is what to try next or why it oscillates in the first place, so my powers of figuring out a solution are pretty limited.
-d
Old 20th February 2006, 01:48 PM   #50
Tube_Dude is offline Tube_Dude  Portugal
Tube_Dude's Avatar
Hi dsavitsk
You are using a LM317 with 100 volts across it?
Jorge
noisy noisy noisy noisy noisy tubeHide this!Advertise here!
Noisy CDM Scorpio(DDMF)! Digital Source 6 25th February 2010 12:50 PM
Noisy Amp vento Solid State 13 16th January 2009 08:45 PM
noisy rectifier tube soundbadger Tubes / Valves 3 13th April 2008 09:38 AM
Noisy PSU? pftrvlr Tubes / Valves 16 2nd July 2007 06:26 AM
help on P1.7 (Noisy) pamaz Pass Labs 9 26th August 2004 02:21 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
