EL84 Amp - Baby Huey
Old 29th August 2018, 04:46 AM   #2161
gingertube is offline gingertube  Australia
Electrically both are OK.
The original STU9HN65M2 is an I-PAK (TO-251-3) device.
The 2 you have listed are TO-220 which have wider pin spacing (round figures 2.9mm for the TO-220 rather than 2.3mm for the I-PAK). You would have to squeeze the pins together a bit but the actually pinout is the same.
I would prefer the first (Vishay) which is all plastic case so no hot (voltage and temperature) tab.
A minor application of the good old "brute force and ignorance" can make them fit and once fitted they will work.
BUT
Aussie Element14 lists the original STU9HN65M2:
http://au.element14.com/stmicroelect...251/dp/2460393
Check Element14 Part Number 2460393 on the Malaysia site. That would be best.
Ian
Old 29th August 2018, 06:23 AM   #2162
kp93300 is offline kp93300  Malaysia
Ian thank you .
I am ordering Element 14 Part Number 2460393. This part is STU9N65M2
I presume it is the same as STU9HN65M2.
The H is missing .
thanks
Old 29th August 2018, 06:41 AM   #2163
It is 5A rated rather than 5.5 Amp and RDS ON is 0.9 Ohms rather than 0.8 Ohms (rounded figures) else the same.
I think it is probably an earlier "incarnation" of the "HN" device.
Ian
Old 30th August 2018, 08:57 PM   #2164
potepuh is offline potepuh  Slovenia
Can I use 330uF, 400V or even 560uF, 400V for the C6? I have some of them already on stock.
Old 31st August 2018, 07:24 AM   #2165
bandol83 is offline bandol83  France
Hi potepuh,
Yes, you can put a bigger capacitor, but it will not fit on the PCB !
Hi Ian,
Nice to see you back on your thread I have waited the end of the third GB before to introduce the KT120 quad to avoid too much confusion about different amplifiers and I will now start a new thread for this last one. By the way did you receive my mail with the last schematic ?
Best regards,
Marc
Old 1st September 2018, 03:26 AM   #2166
SCD is offline SCD  Canada
Hello Potepuh:
I have just recently finished the build of my version of this amp. (pictures soon, should we start a bby huey build thread?).
I highly recommend you go with higher voltage capacitors. If you want to try a range of tubes you will need your voltage to go upto 500v or so. The capacitors on the BOM I used are 450v, Upgrade to the 600 or 650v ones. It will give output tube rolling options, which is pretty great. I am using 6P6S(6П6С, 6v6) and am about to try 6l6gc, and if I can get my filament amperage up I would like to try kt66, and EL34/6ca7 as well.
Marc put up a chart a while back that compares the various tubes in the family.
Comparaison pentodes et tetrodes.pdf
Seems to me 500v gets you into the range pretty good.
I hope this helps
SCD
Old 2nd September 2018, 08:19 AM   #2167
Hi Scott,
I will follow your suggestion and prepare a new thread for building the EL34 Baby Huey soon, since there are already 330 PCB's sold and 20 more in waiting list for a 4th GB
Your suggestion to use 500 V capacitor is very good, but builders should not use higher voltage with this PCB because there could be some isolation problem
In the mean time my EL34 Baby Huey is almost finished (see picture). All this mechanical work is made by Philippe who is much better than me for this task I was lucky to meet him and that he is also living near Bandol in the South of France because before in the past most of my electronic design didn't have a case, now they look professional
Best regards,
Marc
Old 2nd September 2018, 03:30 PM   #2168
Default New thread for building the EL34 Baby Huey
Hi everybody,
As SCD suggested and because the EL34 Baby Huey interest is still growing, I have started a new thread on the building of tubes amplifiers based on this PCB at this address : EL34 Baby Huey Amplifier
I will regularly add information but you are also welcome to show pictures of your amplifiers and to discuss the choice of tubes or others components...
Thanks for your strong interest in this small project
Marc
Old 29th September 2018, 01:46 PM   #2169
sunil is online now sunil  India
Anybody have a spare set of the original ECL86 based PCBs, please message me. I have a spare set of tubes I'd like to try. Thanks.
Old 29th September 2018, 03:31 PM   #2170
Did you speak about this one ?
Marc
File Type: jpg PCL86 avec transfo Hammond 1609 10 kohms.JPG (414.2 KB, 879 views)
File Type: pdf ECL86 & PCL86 Baby Huey 5 oct 2016.pdf (136.6 KB, 171 views)
EL84 Amp - Baby HueyHide this!Advertise here!
Red Light District/Baby Huey (EL84 P-P) Output Iron dsavitsk Tubes / Valves 3 14th February 2009 01:21 AM
Copyright ©1999-2019 diyAudio
