It's called body filler as used on car bodywork. In practice it very hard to get a perfect finish, re filling in holes. A nut & bolt is far easier.I made a few mistakes on my last build and was thinking of gluing some screw heads into the holes before powder-coating but filling and sanding would be much better.
Nice work Alex, where do you get your knobs? Finding the right knobs takes some doing.
Andy.
My plastic casing ccd line amp, with fresh coat of copper paint...
These line amps are good with 7dj8, 7bk7, 7bq7, 6dj8, 6n23, 6rhh8, 6rhh2, 6922, 6cg7/6fq7, 6gu7, and many more others.
There is no doubt that the modeling scheme is produced by AI, and the 300B SE is completed.
This time, there is no doubt that my computer modeling is not designed by artificial intelligence.
Back where I used to work a very long time ago in an engineering lab, all equipment was produced with huge looms of wire running around inside chassis. Techies were actually trained in to do it....things that I personally do not do, like running signal wire from back to front, or bunching wires together just to look tidy.
For sure, it's a big chassis, I bet you I can make it half, same components.
I can do it too!
- Tubes / Valves
- Photo Gallery
