Photo Gallery
Photo Gallery
Old 13th October 2019, 11:22 PM   #9121
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Photo Gallery
thank you,it seems such style switches are in vogue now....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 14th October 2019, 01:43 PM   #9122
kodabmx is offline kodabmx  Canada
Spreading triode love.
Photo Gallery
You're welcome.
They certainly seem to be, but that aren't all equal. The ones I linked are good ones
Old 14th October 2019, 05:54 PM   #9123
SCD is offline SCD  Canada
Question for Koda:
What gain does your Phono circuit have. I am looking for 50 - 60 db for my MC set up.
SCD
Old 14th October 2019, 06:34 PM   #9124
Photo Gallery
In theory it's about 45 or so I think. A 4mV MM cartridge will hit 3VU on a 12" 45, and about 0VU on the average LP. 0VU is 1.228VRMS. If more gain is needed, the input tube can be replaced with a 6N2P (and different cathode resistors) to increase the gain.
Old 15th October 2019, 03:18 AM   #9125
kissabout2002 is offline kissabout2002  Italy
I just few days ago put on simulator the RIAA of kodabmx and is 42 dB with 6N23P as input and 48 dB with 6N2P as input.
to SCD:
is very difficult reach 50-60 dB on RIAA pre-amp. without severe noise problem, unless you insert a step-up transformer like the Lundahl 9206 on the input that is specific for MC cartridge....all the best
Old 15th October 2019, 05:31 AM   #9126
Thanks guys about the phono pre-Amp;
I am going the right route in building an op amp based unit. My MC Cartridge is only 0.2mV output.
Sorry to plug up the thread
SCD
Old 15th October 2019, 08:11 PM   #9127
Photo Gallery
Have a look at this: Moving-Coil Pre-Preamplifiers
Old 15th October 2019, 11:50 PM   #9128
Thanks Koda:
I decided to go with an "Emerald" from RJM audio. Should have it up and running in a few weeks
SCD
Old 19th October 2019, 11:00 PM   #9129
polyphaze is offline polyphaze  United States
Default Class A Balanced Monoblocks
Class A balanced monoblocks, 24WPC
be balanced
Old 23rd October 2019, 02:41 PM   #9130
soundbrigade is offline soundbrigade  Sweden
soundbrigade's Avatar
Send a message via MSN to soundbrigade
Cleaned up my Kedvesem (Darling in Hungarian): added a choke (monyed om the underside, stuffed another potentiometer in (could have been a 100K, but all I had was a 22K), fixed the pilot light (no big blue LEDs at home ...), installed an IEC connector.
Else it is much original shape - DIYtubes/Tom McNallys PCB, 1626 triodes and a 6SL7 as driver. All transformers are Banbury's (now discontinued). Even the choke is Banbury's.
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Photo GalleryHide this!Advertise here!
Copyright ©1999-2019 diyAudio
