Photo Gallery
Photo Gallery
Old 16th August 2019, 06:54 PM   #9071
lavane is offline lavane  United States
lavane's Avatar
Originally Posted by azazello View Post
I have the same amp....very bright tube sound.
Did you use the 6LR8 in UL or Pentode instead of triode? It does have a bit of top end brightness, but the bottom end is pretty good.
Old 16th August 2019, 11:11 PM   #9072
azazello is offline azazello  Bulgaria
azazello's Avatar
It was more 10 years ago, I remember that sound was clear, bright, and almost perfect
Projects: SE GK71, SE 12BQ6, PP KT88, OTL-OCL 6AS7 Gen. Electric, SEs 2A3 RCA, 300B JJ, 6S4S, 4P1L, EL11 Telefunken, 6AS7 RCA, 6S33S, 6S41S, 6S19P, E84L Siemens, E236L Telefunken, headphone ampl. OTL Loftin White 6AS7 RCA,...
Old 17th August 2019, 01:31 AM   #9073
lavane's Avatar
I was very surprised by the bottom end. Pronounced but controled. I don't have tone controls and with a pair of ported speakers I have its almost to much.
Old 17th August 2019, 08:58 AM   #9074
johnson1496 is offline johnson1496  Russian Federation
lavane, excellent implementation of the project
Old 17th August 2019, 04:04 PM   #9075
lavane's Avatar
Thanks. It's very quiet and has been getting a lot of use.
Old 18th August 2019, 06:57 PM   #9076
torrence is offline torrence  United States
torrence's Avatar
A GU-50 SET driven by a 6EM7. I was trying to make something small like the Dynaco ST-35. I started working on this amp in Spring of 2012 after some threads by Wavebourne. It has only taken me 7 years to finish it...
Old 18th August 2019, 07:00 PM   #9077
Bigun is offline Bigun  Canada
Bigun's Avatar
Photo Gallery
looks great!
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 18th August 2019, 07:07 PM   #9078
lavane's Avatar
Very nice. Those little Edcor OPT's sound pretty good. I tried a pair on my spud amp.
Old 18th August 2019, 09:15 PM   #9079
Wavebourn is offline Wavebourn  United States
Anatoliy Lisovskiy
Wavebourn's Avatar
Photo Gallery
Looks well thought out and carefully made!
!!!Warning!!!
Single Ended Class-A-Holism is addictive!!!
Old 18th August 2019, 09:55 PM   #9080
hellotron is offline hellotron  Poland
Hi. In the meantime I committed such a "toddler". Includes: Digital FM radio, Bluetooth, EQ, micro SD / USB reader, aux input, manual tone adjustment. Audio amplifier on 5670 and EL95 tubes, power output 2 x 3W. The whole is controlled from the remote control.
Photo GalleryHide this!Advertise here!
Copyright ©1999-2019 diyAudio
