Photo Gallery
Photo Gallery
Old 18th March 2019, 10:39 AM   #8811
mhouston is offline mhouston  Australia
mhouston's Avatar
Very smart.
Old 18th March 2019, 11:05 AM   #8812
JoeAlders is offline JoeAlders  Netherlands
Originally Posted by andrejg View Post
Two of my toys:
- Aikido LV 48V with added headphone out
- S-5 Electronics K-16LS
That second picture: looks very, very good!
Old 18th March 2019, 11:36 AM   #8813
andrejg is offline andrejg  Slovenia
Thanks. It took some 3-4 tries to get it right. And about 10 years, lol. Whatever enclosure I built was never quite right. What you're seeing is a mashup of 3 failures . I did learn how to hide the mistakes and imperfections.
Old 18th March 2019, 02:54 PM   #8814
adam1016 is offline adam1016  United States
Here’s some photos of my 01A preamp based off Ale’s design. I’m using similar components, russian teflon output caps and russian wirewound resistors, rod coleman regulators with filament bias, and surplus military connectors for the umbilicals. I’ve gotten one channel tested and wired into my system, but am putting testing the other channel on hold for a couple more days until I finish up the chassis. This has been my first project not from a kit, and I’ve learned so much about layout, chassis work, and grounding. My wood shop teacher got some old cherry from a barn a friend of his tore down, I think they’re going to make beautiful chassis, I’m just worried my college dorm room won’t let me bring my stereo.Click the image to open in full size.Click the image to open in full size.
Old 18th March 2019, 10:33 PM   #8815
Sodacose is offline Sodacose  United States
Sodacose's Avatar
That looks great, adam1016! What connectors are you using between power and signal chassis?
Old 19th March 2019, 03:55 AM   #8816
Sodacose, they’re Military surplus connectors from ebay, using a 4 pin for filament +/- on each channel, and then 3 pins of a 12pin(?) for HT+, gnd, and earth. The actual cables are from McMaster.
Old 20th March 2019, 08:57 PM   #8817
elwood625 is offline elwood625  United States
I was always intrigued by "Magic Eye" tubes, so I bought a pair of 6FG6 tubes from a Ham Fest a couple of years ago. I found a pair of cheap PC board VU meter kits from Ebay China and built a nice Magic Eye tube VU meter for grins. I put 3mm green leds under each tube, hard to see in the pics, easy to see at night.
Old 20th March 2019, 09:13 PM   #8818
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
These were called EM87 in the UK and were installed on almost every European reel-to-reel tape recorder as a recording level indicator.
I still think they're pretty
Old 21st March 2019, 04:05 AM   #8819
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Photo Gallery
I've finished today the first integrated version of the amp prototype, will take measurements tomorrow...
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 21st March 2019, 06:11 AM   #8820
dch53 is offline dch53  Australia
Very nice as always!
I like the little bias displays. I had to check what an 8CB11 was.
Photo GalleryHide this!Advertise here!
Copyright ©1999-2019 diyAudio
