Photo Gallery
Photo Gallery
Old 2nd January 2019, 06:10 PM   #8651
soundbrigade is offline soundbrigade  Sweden
soundbrigade's Avatar
Send a message via MSN to soundbrigade
Originally Posted by artosalo View Post
My present project, 845 PP.
At first some tests with output tubes only, driven by interstage transformer and audio generator.
Now with a Williamson style driver board. Not so easy to get +Ub (~720 V) for the tests.
That will keep you warm when the Sibirian Winter comes blowing from Karelia.
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 2nd January 2019, 06:13 PM   #8652
hpasternack is offline hpasternack
Wrap a piece of sand paper around the holesaw and plunge it back through the hole several times until the hole begins to smooth out.
Good idea. Nice work. Thanks, I will give this a try.
for what model of bmw these pretty cylinders / pistons?
They're Nikasil cylinders from a late-model R100, not sure which. I have a pair of matching big-valve cylinder heads, too. Parts are largely interchangeable across a wide range of models/years. I bought them because the price was "too good to pass up" and now they're sitting on my bench and one day after I'm gone my kids will put them in a dumpster.
I know this is the wrong venue, but if you're interested in pics of my motorcycles, I've put links at the bottom of this post.
The 942 cap should be a very good cap anyway.
I would think so. It seems to be competently constructed and well-reviewed in the reports I have seen online, if that means anything. They're expensive enough that you don't feel like you're buying bargain-basement junk, but not so much that you have to struggle to justify the price. The sweet spot, then, along the continuum of cost, fashion, and self-delusion.
https://lh3.googleusercontent.com/2R...=w1167-h875-no
https://lh3.googleusercontent.com/Ex...q=w657-h875-no
https://lh3.googleusercontent.com/nJ...=w1167-h875-no
Old 2nd January 2019, 09:06 PM   #8653
huggygood is offline huggygood  France
you are welcome hpasternack
really beautiful bikes !!
i have a choper bitza /2 with r100 engine
and r75/6,r60/7,r100/7,r75/5,k75rt,k75s,k1100lt and other motorcycles
before your children decide to put your pair of piston cylinders in the trash, send me a mp, I qlqs engine block / 6 mk2 and / 7 waiting for piston cylinders, I would be happy to buy them they are not scratched
Old 3rd January 2019, 02:53 AM   #8654
Merci bien. I think Iíll hang onto my parts for now but give me a couple of days and I will PM you so we can discuss motorcycles without bothering the tube folk.
Old 3rd January 2019, 07:45 AM   #8655
with pleasure !
Old 6th January 2019, 07:39 PM   #8656
kodabmx is offline kodabmx  Canada
Spreading triode love.
Photo Gallery
Finished up the "Consolidation' preamp.
I consolidated a bunch of circuitry into a rather small chassis. There isn't much room left in there to add anything but it has Bluetooth APTX, 24/192 DAC, 128 step relay volume control, relay switched inputs, a nixie to tell which input you're on, those cheap tube level meters, latching relay that remembers if you're on coax or optical for the dac input, a buffer for the outputs, and a line amp good for 10V out for 1V in for driving the monoblocs I'm building using parts from other amps.
Took about three days...
Thought I'd share the pics.
The little transformer makes the power switch latch or not and turns on the rest of the box. 12V switcher powers the tube heaters, all those boards, and a boost converter for the B+. Theres a 200R resistor that acts as an inrush limiter which is switched out by the black relay. The toroid powers the DAC.
Sidenote: These pics were taken with my phone camera! I'm still getting over how good that nixie looks at full quality
Koda
Old 6th January 2019, 09:04 PM   #8657
Duke58 is offline Duke58  United States
Awesome!
Well beyond my skillset. I hope to be at that level some day.
Old 7th January 2019, 12:13 AM   #8658
SCD is offline SCD  Canada
holy moley Koda!
That is some serious shoe horning.
SCD
Old 7th January 2019, 09:47 PM   #8659
alex mm is offline alex mm  Romania
alex mm's Avatar
Default PP EL34
Second PP amplifier, in progres
CD player Onkyo C-N 7050 , Preamp's :Adagio tube
and Goldmund Mimesis 27 , Speakers :Taga Harmony Platinum F-120 Amp's: 2XGoldmund Mimesis9.2, A33, 2XGROMES A260 tube , SARA , QUAD 405-13
Old 8th January 2019, 01:55 AM   #8660
Wavebourn is offline Wavebourn  United States
Anatoliy Lisovskiy
Wavebourn's Avatar
Photo Gallery
Finished prototyping, crossing fingers...
Input: 0 dB (0.775V) RCA, 50K stereo
Outputs: low ohm for 4-6 Ohm and high ohm, for 8-12 Ohm load.
Power: minimum 6W for <1% total harmonic distortions.
Soft asymmetric clipping, negative output resistance for damping of woofers.
Bandwidth: 10 Hz-90 KHz -3 dB, from 20 Hz full power.
Available versions with different output tubes:
EL34
5881/6П3С-Е
Raytheon VT127
4П10С
!!!Warning!!!
Single Ended Class-A-Holism is addictive!!!
Photo GalleryHide this!Advertise here!
Copyright ©1999-2019 diyAudio
