Photo Gallery
Photo Gallery
Old 4th April 2014, 04:34 PM   #6031
845 is offline 845  Israel
845's Avatar
Originally Posted by TheTubeAmper View Post
Where do you get the acrylic covers for your amps, or do you make them, if so, could you explain a bit?
The covers I've ordered from an local acrylic business.
Old 4th April 2014, 04:43 PM   #6032
845's Avatar
Originally Posted by overtheairbroadcast View Post
What is the list of the other tube based equipment in your set up picture?
thank you for interesting!
This is old picture.On top of the stand you can to see pair of 300B Push-pull monos amplifiers and 307A preamp .On the bottom-300B SE amplifiers.
Old 5th April 2014, 04:17 PM   #6033
needtubes is offline needtubes  United States
My latest build was a single ended, single stage amp using the 6C45. I used Vishay/Dale RN/CMF/CPF resistors in all spots except for the grid stoppers, which are old non-magnetic Holco H8. Elna Silmic II are used as cathode bypass caps and output transformers are the Transcendar 'budget' models (hand brushed to give a more pleasing appearance).
The sound is incredibly detailed, although not as three-dimensional as my other SET amps. Absolutely no hum or buzz present.
Old 6th April 2014, 02:35 AM   #6034
Adam King is offline Adam King  Australia
Default 6n1p-ev headphone amp - my first DIY from scratch
Hi all,
This is my first post. I've restored and repaired a few amps in the past, however, this is my first complete build. This amp is from headwize, the Bender design. CRUSHINGLY LOUD! Handle with care.
Came out OK. Detailed sound, even with a slight hum at idle.
Thanks for the inspiration all. Let me know what you think.
Old 8th April 2014, 03:08 AM   #6035
Bigun is offline Bigun  Canada
Bigun's Avatar
Photo Gallery
Originally Posted by ky3ne4ik View Post
Party of spring on March 8. Assembled headphone amplifier for wife. As a gift. Amplifier in cake. Power supply in the stand
Very imaginative!
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 8th April 2014, 05:22 AM   #6036
mhouston is offline mhouston  Australia
mhouston's Avatar
Adam King: good work. Where in Oz are you?
Old 8th April 2014, 06:48 AM   #6037
romicap is offline romicap  Romania
romicap's Avatar
Power supply is missing. There are only a diode bridge and filter.
Galvanic isolation input/output. Power up to 8 watts per channel. Full SRPP. Very good sound. Assembled 5 different amplifiers. It is possible to use any output transformer 500/8/4 Ohms. Suitable transformers from Outdoor Sound Column (operating voltage 70/100V)...effective frequency range of 140Hz ~ 14kHz wide
Good work ,congrate...Like!
Old 8th April 2014, 08:09 AM   #6038
I'm in Canberra. Where are you?
My next project is a ax84 SEL with a KT88 monster. Looking forward to blasting out some sweet tunes!
Old 8th April 2014, 08:21 AM   #6039
mhouston's Avatar
Southern Vic.
Old 8th April 2014, 08:48 AM   #6040
mthoi is offline mthoi  Malaysia
This is my DIY 12AT7/45/845 amp.
Photo GalleryHide this!Advertise here!
Copyright ©1999-2019 diyAudio
