Poll..anyone interested in an Aikido linestage PCB group buy?
Old 11th July 2005, 05:01 PM   #1
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Default Poll..anyone interested in an Aikido linestage PCB group buy?
This is just a preliminary check.
First of all we would have to ask John Broskie's permission.
Secondly I don't think I should be running the groupbuy because to prevent any confict of interest (being a moderator).
Thirdly it is not such a cheap design since it uses tubes and 4 of em...with the added cost of 4 or 5 tube sockets...filament transformer etc.
But it is imo a great design...sounds very good. (I finished mine a week ago)
But there might not be a lot of consensus on tube types/tube rectification vs solid state..
I know that there is possible group buy going on for the grounded grid by Rozenblit...but am curious as well how many would rather try the Aikido?
Aikido design can be found at www.tubecad.com
If you can see the speaker cone move...it's not hifi.
Old 11th July 2005, 07:16 PM   #2
Sheldon is offline Sheldon  United States
I'd try it. I'd like a board mainly for easy mounting. Maybe grounding on the traces and pp elswhere?
sheldon
Old 11th July 2005, 07:37 PM   #3
Hi Sheldon,
You've built one I take it? What do you think about it?
I built mine in too small a cabinet..just to try it out..but I was so chuffed that I decided to rebuild it.
What tubes did you use?
Bas
Old 12th July 2005, 04:06 AM   #4
No I haven't built one, but it's a definite possibility in the future. I like elegance expressed in the general concept. First, I've gotta finish my speakers (Unity Horns, destined to be quade amped) and the amps for them. Then it's a pre/buffer, then a phono stage. By the way, those amps will be based on a Steve Bench design that uses another noise cancellation technique - electronic redirection (or Aikido, if you will). I already have some spare amps and stuff, so one component more wouldn't hurt. I build partly for my main system and partly to learn and I will give the extras to interested family or friends after I pick the ones I will keep. If a pre board were relative inexpensive I'd buy one just to prototype up a unit.
Sheldon
Old 12th July 2005, 09:41 AM   #5
Hi Sheldon,
Even at this early stage I think it is safe to say that the PCB is not going to happen...
The Aikido is just not "famous" enough yet.
Bas
PS..thanks for showing interest.
Old 12th July 2005, 10:27 AM   #6
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
Do you have a picture or schematic or something to go on?
yes, i'm too lazy to search. falling asleep as well.
Old 12th July 2005, 10:45 AM   #7
If someone named Colt45 asks me a question...I answer
Introducing the Aikido
http://www.tubecad.com/2004/blog0011.htm
Aikido Variations
http://www.tubecad.com/2004/blog0013.htm
More Aikido
http://www.tubecad.com/2004/blog0016.htm#MoreAikido
Aikido revisited
http://www.tubecad.com/2005/January/blog0030.htm
More Aikido testing
http://www.tubecad.com/2005/January/blog0032.htm
Aikido Enhancement
http://www.tubecad.com/2005/January/blog0033.htm
Happy reading.
Old 12th July 2005, 07:15 PM   #8
thanks Bas,
I gave it a quick look but i'll have to wait until this evening to get a better look at it.
what tubes would you be using? looks like he makes it use anything.
Old 12th July 2005, 07:23 PM   #9
Yes anything with 2 triodes in the same envelope basically I used 12SN7 and ECC99 because they both used 12V and I had some cheap 12V transformers lying about idly.
Old 12th July 2005, 07:33 PM   #10
James D. is offline James D.  United Kingdom
It doesn't have to be twin triodes.
Any matched pair of triodes can be used as one of the Aikido pairs and get the Aikido advantage. See JBs use of EL34 trioded as Aikido output stage.
One can also build a pentode or cascode input Aikido - again see JBs articles. But the full Aikido advantage is from using triodes.
James
Poll..anyone interested in an Aikido linestage PCB group buy?Hide this!Advertise here!
