Novice Filament Advise Needed.
Thread Tools
Old 24th November 2021, 10:10 PM   #1
WntrMute2 is offline WntrMute2  United States
WntrMute2's Avatar
Default Novice Filament Advise Needed.
I'd like to modify my 300B Radiotorn amps to use DC rather than the AC I've been using. I have both 2.5V and 5V versions of the 300B and would like to use both with minor adjustments or switching from outside the amp. I've done this with AC as I just switch between the 5V transformer and its center tap. Works well in this configuration but I would like to get the hum lower.
I have both Rod Coleman regulators as well as Pete Millett's available. I've tried Millett's with a 6.3V 8A transformer and while I can adjust the voltage down from 5V to 2.5V the temperature of the regulator goes up to 90 C when going to the lower voltage. I think that may be pushing things. I have tried the center tap of a 6.3V 8A transformer but I cannot get the voltage needed - 1.9V is the maximum. I have some bigger heatsinks but oddly they have a larger C/W rating - 4.8 vs 3.8. I am hesitant to try those as a remedy.
I need some expertise as what avenue to explore. Should I just use two different transformers and switch between the two? That method adds some pretty hefty iron and expense.
Old 25th November 2021, 03:03 AM   #2
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
Dissipation in a series regulator can be decreased by using a series or shunt resistor. A series resistor can be added for 2.5V output, dropping some voltage before the regulator. Depending on the value, there may be regulator drop-out at turn-on, which would give a softer start.
A shunt resistor bypasses some current - it should be possible to choose one which works across the adjustment range. The disadvantage of a shunt is that voltage will rise below a minimum current, but a tube heater is not a variable load. So you obviously can't measure the voltage unloaded.
Old 25th November 2021, 09:48 AM   #3
euro21 is online now euro21  Hungary
R.C. regulator requires at least 4-5V headroom between raw DC and regulated DC voltage.So You must use 9V AC -more than 25VA- transformer to achieve 9..10V raw DC.
The dissipation of R.C.= headroom voltage*I heater.
  Reply to this post
Novice Filament Advise Needed.Hide this!Advertise here!
Thread Tools
Novice dreams and novice questions tatagatha Chip Amps 34 2nd October 2016 09:23 PM
Advice needed - "build" USB DAC - DIY novice bakker_be Digital Line Level 0 20th April 2014 02:04 PM
Help needed - Novice PWM Amp - not working [-_-] Class D 44 12th March 2009 09:07 AM
Parallel vs. series filament supply - or another filament idea engels Tubes / Valves 11 13th May 2007 02:06 PM
Box Construction .. advise needed fast kat Car Audio 6 13th April 2004 06:14 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
