Input impedance vs hum/buzz
Thread Tools
Old 14th October 2021, 02:39 AM   #21
jxdking is offline jxdking  China
Originally Posted by stephe View Post
They probably have Hot and neutral reversed. The narrow slot to the ground pin should read 120V.
I tested, and the polarity is correct. Based on computer's UPS indicates, the ground wire has voltage present. My AC test pen also confirms that. I think the ground is just open, because I regularly touch my computer case and never got shock.
Even though, it is not related to my hum problem. My receiver and the st-70 are all 2 prong plug.
Old 14th October 2021, 02:43 AM   #22
stephe is offline stephe  United States
stephe's Avatar
Originally Posted by jxdking View Post
You probably are correct. Probably I will change it to 3 prong cord.
Side story, I don’t trust the ground coming out of my house wall, which is built in 1960s. My computer’s UPS reports “Faulty Wiring” on those outlets.
That sounds safe... How did you determine the "polarity" is correct with no ground reference at the outlet?
Old 14th October 2021, 02:51 AM   #23
I did some test with different audio source with my dynaco st-70.
1. Costco Yamaha 7.1 audio receiver, HUM
2. Laptop with AC adapter plugged in to the wall, NO HUM.
3. Bluetooth receiver with USB power adapter plugged in to the wall, NO HUM.
Here is my observation.
When it hums, it is somehow ground looped without grounding any of my device. All of my devices used are just 2 prong plug. How? Here is my hypothesis. The big power transformer like the one in dynaco st-70 has some stray capacitance across primary and secondary. Thus, they can ground loop through the neutral and live rail in side the wall.
Old 14th October 2021, 02:55 AM   #24
rayma is offline rayma  United States
Measure the stray AC voltage between the ST70 chassis (with no input) and the AC line safety ground.
If you measure any AC voltage, try reversing the ST70 AC plug in the wall socket and check again.
The leakage can be asymmetrical.
Old 14th October 2021, 03:33 AM   #25
stephe's Avatar
The neutral is connected to earth regardless of whether the cord also has a safety ground or not.
Old 14th October 2021, 03:41 AM   #26
I stick my ac tester pen in the longer slot from the wall socket. It does not light up. It will light up in the shorter slot and the ground hole.
Old 14th October 2021, 10:20 AM   #27
Depanatoru is offline Depanatoru  Romania
It doesn't have to be a ground loop ... just bad grounding in that Yamaha .
If the metal case , which is probably touching the output RCA ground , is not connected properly it will hum ... probably is good enough for other amplifiers but for not for ST70
Old 15th October 2021, 12:06 AM   #28
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
This sounds like the wall socket is incorrectly wired. Find and open the breaker for that outlet and observe the socket wiring by colors. If you can't see the error, it may be at another socket (typically in the same room, but nearby). Do not use this socket until the error is corrected.
Generally, you can trust the $10 plug-in three-light testers to tell you the truth, so one is a great investment.
Be safe, and all good fortune,
Chris
"A marveilous newtrality have these things mathematicall and also a strange participation between things supernaturall, immortall, intellectuall, simple and indivisible, and things naturall, mortall, sensible, componded and divisible." - John Dee
Old 15th October 2021, 12:09 AM   #29
Very bad and dangerous. You need an electrician.
Old 16th October 2021, 11:02 PM   #30
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by Chris Hornbeck View Post
...Generally, you can trust the $10 plug-in three-light testers to tell you the truth, so one is a great investment...
They will not detect an N/G swap. Or a bootleg ground.
i.e.: they will tell you an outlet is wrong, but can not prove it is right. ENTIRELY worth the $9. I have several. But if I need to know, I have an expert trace the wiring from the street to the listening room.
John at another forum worked on a smarter tester.
Input impedance vs hum/buzzHide this!Advertise here!
Thread Tools
NAD C315BEE Buzz, replaced capacitors, now new kind of buzz thecopy Solid State 0 16th January 2015 03:29 PM
Buzz/Hum from Audiosector LM3876 board itself - no buzz in speakers dakku Chip Amps 4 12th April 2014 03:51 PM
buzz buzz... probleme with VSPS 6ri.l Analogue Source 0 19th August 2010 05:41 PM
Melos triode and computer as source: BUZZ BUZZ BUZZ zigo3 Tubes / Valves 4 28th November 2007 03:11 AM
need help with carputer install, buzz/hum Chris in NH Car Audio 6 27th September 2004 05:04 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
