EL84PP, a simply circuit
Thread Tools
Old 4th October 2021, 11:49 AM   #11
huggygood is offline huggygood  France
huggygood's Avatar
@ Walter.
would you like to start a small pcb production?
I have a lot of EL84 and good output transformers in my stock.
Tempus fugit
Old 4th October 2021, 11:57 AM   #12
waltube is offline waltube  Italy
waltube's Avatar
Hi
the OT are custome made for me.
About 84 please let me know the brand and quotation
Walter
Old 4th October 2021, 12:01 PM   #13
waltube's Avatar
to 6A3,
thx for appreciation.
The sound is very fine.
About OT I will give, for info the specification and the costs with p&p
Walter
Old 15th October 2021, 05:27 PM   #14
brimax is offline brimax
hi walter ... how does it sound compared to well known EL84 amplifiers (eg Leak Stereo 20 I've heard some months ago)? thx
Old 15th October 2021, 06:27 PM   #15
kevinkr's Avatar
Looks great Walter! The output transformer sounds very interesting.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 16th October 2021, 06:53 AM   #16
waltube's Avatar
to huggy
the pcb are arriving soon.
They cost 25eu. each + p&p
to brimax
I know very well the Leak that is a reference , but also other stuff.
Due the OT trafo with an high ratio I lost just few power ( 8 ohm resistive load) but it is capable to drive complex loudspeaker with a good efficency.
The sound seem to be very complete from bass to high with more "life" respect the Leak (p.e.)
to Kevinkr
The OT is very good stuff as the test lab says.
The little company who wound thse types of trafo use a beautiful machine comes from a hiend brand in Switzerland; I consider it is the best machine ( it is old ) to wound perfectly the bobbin. This is one of the major step I have seen.
Also the C core 0,1mm laminated helps. ( I use only C core on OT trafo)
I have ready also a s.e. for 300B and is coming a p-p for EL34/KT88
The costs are not low ( also because the numbers of production are not high)
All OT for p-p are always with one single tap on secondary and no UL connection ( only under request); in my opinion the tetrode/pentode connection is more exiciting.
I am preparing also a internet page to list the stuff with all real test lab.
With a help of my friend in Audioelettronica
Walter
  Reply to this post
EL84PP, a simply circuitHide this!Advertise here!
Thread Tools
Simply tube based RIAA circuit Ayot Analogue Source 3 5th April 2016 09:58 PM
Best EL84pp kit?? Fsatsil Tubes / Valves 41 21st August 2010 11:38 PM
Partial Feedback EL84PP - Not quite as expected (yet) Svein_B Tubes / Valves 44 18th May 2008 05:59 PM
New Jensen caps has no bass in..Simple EL84PP aroS3 Parts 5 8th December 2006 05:29 PM
Is feedback required for UL EL84PP? leadbelly Tubes / Valves 10 25th January 2006 11:01 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
