Coupling caps
My Accuphase E-303x amplifier has a 12dB/octave subsonic filter -3dB at 17Hz, essentially -0dB at 40Hz. Without the high pass in circuit the MC input to speakers is DC coupled with response -1dB at ~1Hz. When the subsonic is switched in it changes the whole character of the low end of the system, which loses it's sense of effortless, bottomless bass.
If there must be a high pass filter in a system, there should only be one with a pole near the audio passband IMHO. All other couplings should have their -3dB point ~1Hz or lower, simply to prevent excessive phase shift in the passband. I'd be using 22µF.
I certainly have no speaker modulation problems with my Dynavector XX2 on a Rega RB301 tonearm / 1972 Planar 3. I do a lot of mid-high end turntable setups and would not return a turntable to a customer that cannot play my warp test, which is fairly extreme. I've never come across a record that presents a problem for subsonic modulation in real life, except on very poorly matched turntable / tonearm / cartridge combinations that don't belong together or in a hifi system.
Couldn't get enough bass compare to SS amp so I decided to upgrade from 0.47uF to 1uF, the original design was 0.1uF. It's so good now, can get both mid/bass perfect well. The mid is so clear and i don't want to miss out of the bass, that's why I went ahead to upgrade.
By the way, one of my new coupling cap can spin both legs around 360 degree at the same time. Is it bad? I check the measurement where it shows correct 1uF. I am afraid to use it. I don't know if it's just the cover outside has nothing to do with it.
I bought it's 2 years ago so probably they won't take back. I think the leads soldered well together since I turned the lead on one end, then the lead other end turn as well. What would be a problem if the coupling cap fails or dies in the circuit? As long as it doesn't burn or explode, then I can try. I am afraid it blows up.
