Heater Bias with Rod Coleman Fil Regs
Thread Tools
Old 29th September 2021, 03:25 PM   #31
Rod Coleman is offline Rod Coleman  United Kingdom
садовник
Rod Coleman's Avatar
IMHO the difference in sound between 300B types is smaller than difference between good and EXCELLENT OTs, anode supply, Filament supply, and driver stage design and power supply.
So if you don't have a Sowter, or Monolithic OT, I would start there. OTs - even high cost ones are good value, and last a lifetime.
Old 29th September 2021, 05:02 PM   #32
Cagomat is offline Cagomat  Germany
IMO the most important criteria of amplifier design are:
1.) Power supply
2.) Power supply
3.) Power supply
4.) Driver stage
5.) OPT
6.) Power tube
Old 1st October 2021, 10:48 AM   #33
goddlediddles is offline goddlediddles  Ireland
goddlediddles's Avatar
Default How does it work?
Hi Rod. I can't find a comprehensive description of how your filament bias device works. Could you direct me to an explanatory article with a link? Thanks.
Always make up your own cables.
Old 2nd October 2021, 10:43 AM   #34
садовник
Filament Bias is a simple technique to apply cathode bias, but with a low-value resistor. The goal for doing it is to have a low enough value of cathode resistor, that the bypass capacitor is no longer needed.
For valves with reasonably low filament current, and low bias voltages, it is a good solution. But for something like a 2A3 (45V bias, 2.5A current: = >110W burned in the resistor) the heating power in the filament bias resistor is far too much.
Before building any stage with filament bias, be sure to check the power burned in that resistor. If the power is too high, grid bias, aka 'fixed bias' is the best solution that allows the bypass capacitor to discarded.
IMPLEMENTATION: My application note for Filament Bias - giving instructions on how to build it for the 26 or 4P1L, including transformer choices and Raw DC design, and a sample preamp circuit are given here:
http://lyrima.co.uk/pdf/FilamentBias_Supply.pdf
Old 2nd October 2021, 11:40 AM   #35
Thanks for that. So it looks like the 300B might be out too?
Old 2nd October 2021, 12:41 PM   #36
садовник
Yes for 300B, auto-bias or grid bias are the practical choices.
  Reply to this post
Heater Bias with Rod Coleman Fil RegsHide this!Advertise here!
Thread Tools
IDHT Bias with Rod Coleman Filament regulator Cagomat Tubes / Valves 20 17th September 2021 01:04 PM
FS:Dave Slagle filament modules and Coleman regs crazy bill Swap Meet 4 4th July 2020 08:13 PM
SET Rebuild (Fixed Bias and Rod Coleman DHT Regulators) Jose R Tubes / Valves 8 14th December 2016 10:17 PM
FS: 34 pcs. ST and globe 26 tubes and Coleman regs. mctavish Swap Meet 10 7th February 2016 03:52 PM
Poly-fil NU-FOAM for speaker stuffing/lining? turbodawg Multi-Way 10 10th December 2012 01:31 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
