Antique Sound Labs KI22 Fox
Thread Tools
Old 14th September 2021, 06:49 PM   #11
itsgarth is offline itsgarth
Originally Posted by audiohead View Post
What is the primary impedance of output transformer T2?
Art
Not sure...
I'd have to take the amp apart again to test it
and it doesn't show on the schematics
Old 14th September 2021, 08:16 PM   #12
Koonw is offline Koonw
Input tube should be 6sl7 for both, that's likely to be a mis-print. Attach is a sketch of schematic.
Old 14th September 2021, 09:29 PM   #13
Thanks for your help Koonw
I finally found a copy of the manual that came with my amp.
I remembered it having a tube chart but it also had a schematic with it!!!
I've scanned it to pdf and included it here.
now to try and figure out the diferences
Old 14th September 2021, 10:07 PM   #14
audiohead is offline audiohead  United States
Just in case if u r interested to measure the primary impedance of the output transformer:
N1/N2 = V1/V2
Z1/Z2= (N1/N2)^2
Z1=Z2*(N1/N2)^2
Where: N1/N2 turns ratio
V1/V2 : Primary voltage/Secondary voltage
Z1= Primary impedance
Z2= Secondary impedance
You need to have an audio generator set to 1KHZ connected to the secondary an ac voltmeter or scope to measure the primary voltage of the output transformer. The amp must be powered off and secondary not terminated.
Then use the above formula to calculate the primary impedance.
Art
Old 15th September 2021, 02:01 AM   #15
If indeed the 1st stage is 6sn7, the operating points would be quite different some thing like 60V on the plate compared with 152V when it's 6sl7.
Old 15th September 2021, 03:20 AM   #16
There are indeed 6 6SN7s in the amp.
6SN7EH's to be specific.
I took pictures of it when I was working on it.
once I have more energy I'll haul it back out to the shop and take some measurements.
  Reply to this post
Antique Sound Labs KI22 FoxHide this!Advertise here!
Thread Tools
Antique Sound Labs T-1X DT Preamp dtm1962 Swap Meet 2 24th November 2019 04:22 PM
Antique Sound Labs T-1X DT Preamp dtm1962 Swap Meet 0 24th November 2019 04:17 PM
FS : Antique Sound Labs AQ-1003 PCB for DIY (INTEGRATED AMP EL34 PP) ANALOG GUY Swap Meet 7 21st April 2012 12:23 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
