Sound advice !
Sound advice !
Thread Tools
Old 14th September 2021, 05:22 PM   #21
Cagomat is offline Cagomat  Germany
Originally Posted by Brian28 View Post
Guys .. be gentle ..I’m a mechanical engineer ..🤷 ..and I can build the amp from the drawings but fault finding is the real art ..
I have attached the schematic with some Ac voltages and DC .. please let me know what else you need .. can you make it simple as well
Cheers Brian
the 14V AC on the anode of 300b is way too low. Please control the wiring of your monolit output transformer, and measure the inductance of the primary winding
Old 14th September 2021, 05:25 PM   #22
Brian28 is offline Brian28
Originally Posted by TheGimp View Post
It looks like the C3Mis amplifying properly.
You have 114VAC at the grid of the 300B.
However you only have 10.4VAC on the plate of the 300B.
You should be approaching clipping with at least 200VAC on the plate.
Something appears to be wrong with the load on the 300B.
Hi , where does the load on the plate come from ? .. OPT ?
Old 14th September 2021, 05:31 PM   #23
yes the opt primary
Old 14th September 2021, 06:07 PM   #24
AndreK is offline AndreK  United States
Sound advice !
Brian,
Are you sure your OPT primary connected to 300B, not secondary?
Old 14th September 2021, 06:15 PM   #25
Its a little bit confusing, the voltage across the primary winding is 15v the dc resistance of the Monolite opt is 105 ohm. 15V/105 ohm is 146 ma.
Old 14th September 2021, 09:10 PM   #26
Ok ,been in the workshop for a few hours checking everything again .. how about a schoolboy error �� .I seem to have labelled up the pins on the 300b’s incorrectly..
what a knob ��.
I have rewired and fired it up again .. now there seems to be much more volume on the workshop speaker ….I’m going to fire it up again tomorrow and check the voltages again and perhaps try it again on my system ..
I’m hoping that’s the problem ..
Old 15th September 2021, 05:50 AM   #27
Diabolical Artificer is offline Diabolical Artificer  United Kingdom
Diabolical Artificer's Avatar
what a knob
Easily done, I've executed some right howlers, away with the faeries, brain only running on one cylinder.
Good your making progress, Andy.
  Reply to this post
Sound advice !Hide this!Advertise here!
Thread Tools
Sound, sound beautiful sound Atk1d Tubelab 2 23rd April 2014 02:23 PM
Need some advice where to install LED, also power socket advice. Mull3t Construction Tips 14 28th May 2012 04:32 PM
Sound, Sound, and more Sound - Instractables Nordic Everything Else 0 5th March 2008 05:43 PM
"Sound Advice" for Class D jackinnj Class D 0 4th May 2005 01:19 PM
Poster in Musical Instrument forum needs bridging advice on BrianGT 4780 advice moving_electron Chip Amps 0 16th February 2005 12:37 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
