Plate chokes - choosing and using
Thread Tools
Old 15th September 2021, 05:12 AM   #31
Paul Joppa is offline Paul Joppa  United States
Nothing special in this post, just validating that the Hammonds work as expected as plate chokes, within their ratings.
Some years (decades?) ago I build a preamp test bed with several switchable chokes 30H to 72H if I recall correctly. The tube was a 6BL7, rp 2K2. There were four different inductances, and each increase was an audible improvement. (I was mostly listening for midrange clarity/resolution at the time, not frequency extension.)
I added a current source to the options, and that seemed clearly better than any choke, but it shifted the operating point too far to call it a valid comparison.
I've also used the 157G in a prototype 2-watt amp with 6DN7, rk 2K5, parafeed into an 8K:8 ohm output transformer driving an 8-ohm speaker. It worked without issues, but neither the choke nor the transformer I used was adequate for very deep bass - see first paragraph.
Old 15th September 2021, 07:00 AM   #32
andyjevans is offline andyjevans  United Kingdom
Good to hear your very extensive experience, Paul. Thanks for coming in.
I also have found that each increase in inductance was an audible improvement, again in midrange clarity. I'll have to get my Bartola gyrators working - some glitch I haven't fixed.
Could you say something about comparing plate chokes and active loads to a plain resistor load?
  Reply to this post
Plate chokes - choosing and usingHide this!Advertise here!
Thread Tools
Sowter & Electra-Print Parafeed transformers and Plate Chokes. Also Lundahl 1676 carlsor Swap Meet 1 29th January 2019 02:12 AM
Kool Mu core chokes for the class D output chokes? rhythmsandy Class D 12 23rd October 2017 08:10 AM
FS: 4x 10H 215mA WIDEBAND CHOKES (layered chokes) DIYspaceW Swap Meet 5 13th March 2013 05:10 PM
EL84 PP using 5K plate to plate primate OPT jmillerdoc Tubes / Valves 5 9th March 2010 09:14 PM
Plate chokes & Power chokes JC951t Tubes / Valves 3 19th October 2006 03:18 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
