More help with low watt output stage please
Thread Tools
Old 22nd July 2021, 02:47 AM   #31
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
Why is there a voltage divider at the intersection of first and second stages of the preamp? Also, why the double output capacitors?
Calculation of gain reduction by feedback should be a factor of (21.2 + 4.9) / 21.2 = 1.23 or about a smidgen in dBs.
All good fortune,
Chris
"A marveilous newtrality have these things mathematicall and also a strange participation between things supernaturall, immortall, intellectuall, simple and indivisible, and things naturall, mortall, sensible, componded and divisible." - John Dee
Old 22nd July 2021, 03:19 AM   #32
gary h is offline gary h  United States
Thank you Fuling, I think I had the grid leak and grid stopper resistors backwards. Chris, is that the voltage divider you are referring to? I will clean this up in next version. As far as the two output caps, a feature of the Aikido pcb is that it affords room for two or three different output caps. I neglected to draw in the switch that selects 1,2, or both. Currently I have a paper and poly cap. I cant tell the difference between them, so I like to think they both sound good.
Old 22nd July 2021, 04:08 AM   #33
Now I re read your question, you are aking about the voltage divider within the preamp. I will not do justice to that question, but I will happily refer you to the tubecad notes that explain. As far as I ca discern, it has something to do with the way the Akido circuit cancels out PS noise by playing two halves of each triode against the other. I will look for the link that explains
Old 22nd July 2021, 04:11 AM   #34
By the way Chris, would you care to reflect on the meaning (to you) of your tag line. Every time I read it, I think of a guy in a white wig noticing the similarities between curious electrical phenomenon and human behavior.
Old 22nd July 2021, 04:36 AM   #35
I believe the answer to your question about the preamp circuit lies here:
New Tube Circuit: The Aikido Amplifier
This is th page that I remember reading before building the premp. Beware, it mentions genius, so read at your own risk.
Old 22nd July 2021, 04:51 AM   #36
So they're to protect against catastrophic stupidity. Happens, I guess.
John Dee was an alchemist (but so was Newton) who saw the way forward into science, at a time when people still believed in witches. We're now living in a time when science, or even clear thought, is devalued. Foolish, foolish humans.
All good fortune,
Chris
  Reply to this post
More help with low watt output stage pleaseHide this!Advertise here!
Thread Tools
High power output PORTABLE headphone amp (1-watt ot more) 1z2a3y Headphone Systems 36 29th November 2020 05:31 AM
How does sound output on 700 watt compare to low down studio 110. skyler440 Solid State 3 16th August 2013 11:39 AM
Low noise resistors, cheap, 1/4 watt 1/8 watt makingmoney Solid State 13 18th February 2013 03:22 PM
CFP output stage adding more output transistors diy didi Solid State 2 2nd February 2013 06:15 PM
Common emitter stage driving low hfe output stage Fusion916 Solid State 1 20th December 2012 05:05 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
