How to use solid state rectification the best way
Thread Tools
Old 28th July 2021, 04:23 AM   #71
tvicol is offline tvicol  Europe
tvicol's Avatar
@trobbins, nattawa did a great job by measuring and comparing in this thread Impression of LT4320 and Ideal-Bridges. They are cool, and quiet too.
Tibi
https://evotronix.eu
Old 28th July 2021, 04:50 AM   #72
trobbins is offline trobbins  Australia
trobbins's Avatar
Tibi, I wouldn't say nattawa did 'a great job', and in review the comparison was quite flawed wrt 'noise'.
The scope plots are ambiguous as to what is shown and labelled - it appears that a probe tip was placed 'near' the large 10mF output capacitor, with no indication of where the ground clip was placed, or a photo shown of layout.
And it wasn't an apples-apples comparison, as it seems that the kool-brg has an smt 2.2uF bypass cap across the +/- terminals, which is likely to be the dominant suppressor of the ringing shown from the Sanken diode bridge.
What could have been a better comparison test is to custom place a smt 2u2 cap across the Sanken bridge legs, or remove the 2u2 cap from the kool-brg module. An analog scope may also be limited in identifying an apples-apples comparison, and it may be better to use a probe connected to a known point and use soundcard/spectrum analyser software to see a subtle difference that is down in the noise floor.
PS. there is also a concern with comparing a 50A pn diode bridge to a synch solution when the application is really down at the <<10A device rating region.
Old 28th July 2021, 02:59 PM   #73
astouffer is offline astouffer  United States
astouffer's Avatar
I'd like to see a way for the LT4320 adapted to higher voltages.
Old 28th July 2021, 03:27 PM   #74
tvicol's Avatar
LT4320 maximum allowed voltage is mainly limited by his internal regulator. This internal regulator is self-powered by mosfet-bridge. In the same time drain sense voltage are internally connected for each mosfet to internal controller. This make impossible to use an external regulator to increase LT4320 voltage operation.
Tibi
  Reply to this post
How to use solid state rectification the best wayHide this!Advertise here!
Thread Tools
Solid Solid State Power Amplifier PMA Solid State 265 30th August 2011 08:04 PM
solid state Vs Tube Rectification sandy Tubes / Valves 3 3rd September 2004 04:20 AM
The Solid State Wiki - Your solid state reference guide Jason Solid State 0 25th June 2002 05:26 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
