low power bedroom amp
Thread Tools
Old 8th April 2021, 05:31 PM   #111
Shoog is offline Shoog
Shoog's Avatar
The HIFI crowd gave up on tone controls in the 80's. There was a good reason for that.
Shoog
Old 8th April 2021, 06:54 PM   #112
Lingwendil is offline Lingwendil  United States
Lingwendil's Avatar
Shelving EQ is probably the only tone control I care for, and that's for setups that specifically need it for baffle step compensation.
6SN7 Push-pull Flea Amplifier PCB files are now available!
Old 8th April 2021, 06:54 PM   #113
wg_ski is offline wg_ski  United States
Originally Posted by kodabmx View Post
If someone can show me how to design a "simple" bass and treble control, I'll build it.
30Hz shelving EQ for bass, 16kHz shelving EQ for treble. I don't know how to do that except for parametric EQ or DSP.
This is interesting, but not simple. TC Electronic | Product | ANORM
A Baxandall won't cut the mustard.
I find that Baxandalls work fine for *me*, but only if I set the corner frequencies two octaves from where mass produced amps put them. Where they usually are, they affect the midrange too much. You donít have to put them there, you can make the cap values whatever you want. 15 dB boost at 100 Hz (and 9 at 200 along with it) is YUCK. 15 at 25 is niiiiiice, because that limits the boost at 100 and virtually all of it at 200.
But what you may be looking for is a 12dB per octave shelving network, which you cannot make (passive) with just resistors and capacitors. You can get there by by summing the output of a straight path plus a variable amplitude of the output of a 12dB/oct low pass filter (unless you are also allergic to sallen-key filters).
Old 8th April 2021, 07:45 PM   #114
kodabmx is offline kodabmx  Canada
Spreading triode love.
kodabmx's Avatar
A very good point about moving the frequencies in the Baxandall... For some reason I hadn't thought of that. If the corner points are extreme enough, a bell curve is good enough
Ask me about PCBs and kits for DIY tube projects.
Old 8th April 2021, 07:58 PM   #115
kodabmx's Avatar
A client wanted a tone control in the preamp I'm building him...
I ordered the blank first.
Then I realised it's only 5$ more for a complete. So I bought that. Then I paid Mouser like 60$ for the parts to populate the blank. FML.
12AX7 Dual Channel Baxandall Vacuum Tube Tone Board Type Low Distortion Adjust | eBay
If anyone wants to help change the frequencies from whatever they are to 30Hz/16kHz, I'm all ears Filter design isn't my strong point.
Old 8th April 2021, 08:07 PM   #116
Chris Hornbeck is online now Chris Hornbeck  United States
Chris Hornbeck's Avatar
? A Baxandall tone control is already a sliding turnover frequency. It's not possible to make its frequency response slope greater than 6dB / octave.
YOS,
Chris
"A marveilous newtrality have these things mathematicall and also a strange participation between things supernaturall, immortall, intellectuall, simple and indivisible, and things naturall, mortall, sensible, componded and divisible." - John Dee
Old 8th April 2021, 08:20 PM   #117
kodabmx's Avatar
That's why a Baxandall isn't good enough... 12-24db/octave would be impossible with it.
My client wants a tone control. I want a good tone control
Old 8th April 2021, 08:36 PM   #118
YOS,
Chris
Loudness controls donít do better than 6dB per octave either. There is only so much you can do with an R and a C.
To go to 12dB/oct, you need one resonator. To go to 24, you need two. Resonators can be made with an L and a C or two Cís and an *amplifier*. Inductors are big. Amplifiers use power (and potentially use feedback which you may be allergic to). Pick your poison. Baxandalls need amplifiers too. So do passive tone stacks that look like Baxandalls because you need a gain stage to get the level back.
  Reply to this post
low power bedroom ampHide this!Advertise here!
Thread Tools
Nikko A-300D My bedroom amp developed distortion Ronj Solid State 9 14th August 2012 03:29 PM
little bedroom/desk amp? albireo13 Class D 11 15th November 2010 05:42 AM
Speakers for bedroom 5th element Multi-Way 3 9th April 2004 09:50 AM
sound deadening a bedroom?? need ideas.. lol SkinnyBoy Everything Else 45 24th January 2004 02:28 PM
Looking for opinons about 5 x Alelph-5 for bedroom HT. eclam Pass Labs 3 11th April 2003 07:44 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
