simple preamp from half 12ax7
Approximately half of your B+ supply voltage will appear across the ? resistor, so it will also dissipate about the same power as the MOSFET. It's value is simple Ohms Law: R = Volts (about 150 for your case) divided by Current desired.
Only you can know what current is desired because you're keeping that a secret.
YOS,
Chris
hi again.
All the parts arrived, I started building the pre amplifier.
It works well, makes a bit of noise, probably power or GND.
12au7 works great for gain.
The spectrum picture is not so good. no 2nd harmonics
If you have the parts, you can try 47k plate resistor and 220R - 330R on the cathode for a 12AU7. With a 300k plate load, the 12AU7 is so current starved it's virtually worthless :(
Otherwise, use 12AX7, and a voltage divider on the input to reduce the gain (or install negative feedback).
work good. thanks
Try extra decoupling on B+.
yes it help
Summary:
pcm56p DAC 1ma output to 100ohm
12au7 with 47k plate resistor and 220R - 330R on the cathode
