Hi! This is the current scehmatic ... current values.
Please do not consider yesterday's data, slightly different, especially in the B+.
Currently (V2) the voltage value set by the 1n4148 diodes is slightly different from the value obtained with the 2K resistor. I will update it with right diodes.
https://ibb.co/9VWJwz9
Basically it's an "almost" copy of Audioresearch ...
https://ibb.co/QXxrVDc
change R4 and R8 to 100K.
-g
100k are values I see in guitar amp schematic!
in the schemes of hifi devices ..... of prestige..no less than 270k.
why your idea? What is the good?
.. are you sure you mean r4 and r8? I think you meant .. r4 (330k) and r5 (330k).
1. looks like clipping to me. changing the plate resistors lowers the gain.
2. has nothing to do with the eq..... just give it a go, and let us know...
- Tubes / Valves
- Problem with led bias on phono preamp...
