Felt damping
Felt damping
Thread Tools
Old 22nd January 2021, 07:52 PM   #1
tonescout is offline tonescout
tonescout's Avatar
Default Felt damping
Hello - just a quick note to share the virtues of wool felt as a suitable vibration absorbing material. I have been a fan of felt since early vinyl days experimenting with different platter mats, and once again it has come good.
The reason for the post is to share a surprisingly effective solution to a mechanically noisy transformer on a large 211 amp. The amp is heavy and has the typical 50 Hz drone when it is operating. It is not a huge noise and I have been happy to ignore it as it is pretty much inaudible at the listening position. The amp sits on a wall shelf made of 50mm plywood with very strong wall brackets secured by 12mm wall bolts. The amp weighs 50Kg+ (yes really) and the 4 shelf brackets are capable of around 300 Kg together. The amp chassis is made of a combination of 15mm aluminium plate and bog oak which has properties resembling ebony for hardness.
I had previously thought with such high mass, and inherently inert materials the mechanical noise was the transformer within it's mounting.....but today I reduced the hum considerably by placing 3mm thick felt pads under the wooden feet (2" diameter solid wood feet). This was actually no mean feet lifting the amp to get the felt feet pads underneath at each corner....
If you have the opportunity and want to experiment with vibration isolation for very little cost, I cannot recommend felt highly enough. The only real expense is time as the materials cost is minimum.
Good luck
Old 22nd January 2021, 09:42 PM   #2
WntrMute2 is offline WntrMute2  United States
WntrMute2's Avatar
I have always "felt" that "felt" was a good product for damping unwanted vibrations. No, really!
Old 22nd January 2021, 10:51 PM   #3
dgta is offline dgta  United States
Where did you get 50mm plywood?
Old 23rd January 2021, 12:04 AM   #4
trobbins is offline trobbins  Australia
trobbins's Avatar
Pretty much any compliant mat under each foot that compresses about 40% of its height when the amp is placed on its feet would do. Cheap options that come to mind are rubber sheet, oven silicone products, old mouse mats, old sorbothane foot heel inserts. The ability to compress a certain % is key to the mat acting as a spring (with damping). If you 'dong' the amp and can measure the fundamental resonant frequency of the amp as it vibrates (by an electret microphone or cheap accelerometer), then the aim is for the vibration frequency to be sufficiently below mains frequency that the mat acts as an attenuator to vibration passing to the shelf (the standard principal of industrial vibration attenuators).
Old 23rd January 2021, 06:30 AM   #5
PRR is offline PRR  United States
PRR's Avatar
Felt damping
Originally Posted by trobbins View Post
...compresses about 40%
.....measure the fundamental resonant frequency .....
The fundamental frequency can be figured from the static deflection.
https://www.industrial-electronics.c...s/aa-279-2.jpg
https://ocw.mit.edu/courses/mechanic...rec10note1.pdf
The difficulty in most work is that "sufficiently low" is approximately "annoyingly large deflection".
In a car engine, older cars could want inches of deflection, meaning much clear space under the hood. With control of engine proportions we tend to higher RPM (higher F) engines which can do with less deflection.
Old 23rd January 2021, 06:47 AM   #6
trobbins's Avatar
Yeh I forgot to check my own notes (page 4 of link) on that before posting, soz for the misdirection:
https://www.dalmura.com.au/static/Mi...n%20valves.pdf
Old 23rd January 2021, 07:15 AM   #7
Originally Posted by PRR View Post
In a car engine, older cars could want inches of deflection, meaning much clear space under the hood...
I assume you're talking about the deflection in the engine mounts. The large deflection has to do with the engine reaction torque under acceleration, not the engine vibration. Engine vibration never required inches of deflection.
Old 23rd January 2021, 09:07 AM   #8
painted is offline painted  Luxembourg
It is all a matter of energy transfer, as we were once taught in high school
Old 23rd January 2021, 09:29 AM   #9
tonescout's Avatar
or lack of transfer....it's sort of a mechanical impedance mismatch preventing transfer and absorbing energy
Old 23rd January 2021, 09:37 AM   #10
Exactly, you want to lose energy in this case. Like losing magnetic field strength with the addition of barriers from different metals.
Felt dampingHide this!Advertise here!
Thread Tools
Felt vs. denim insulation for damping? DaveFred Multi-Way 10 17th April 2019 10:31 AM
Vibration Damping or Acoustic Damping for Sealed Sub? 88man Subwoofers 6 11th May 2015 07:32 AM
Damping sheets - constrained layer damping. deeperthought Multi-Way 14 12th December 2014 08:02 AM
Jute Felt for cabinet damping? RickH Planet 10 hifi 2 19th November 2012 08:24 AM
Quad ESL 57 and Felt Damping owenhamburg Planars & Exotics 7 16th September 2011 09:19 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
