Spiral heater and basing arrangement for lower hum in low-level stages.I've heard that the 6EU7 has a spiral heater which is supposedly similar to a 7025. Not sure why they would use both it and a 12AX7 in the same unit either. They did use 6EU7s a lot. Could it be that the bean counters figured there would be less labor cost if only two heater pins were involved??
Description from GE data sheet:
All versions of the JJ 12AX7/ECC83 have Spiral Filaments (short plates, long plates, gold pins, and regular pins).
All those tubes are re-tested, including for noise, before they are shipped from Eurotubes.com.
Get them there.
They are in the US, but ship to some overseas locations too.
Get them there.
