DHT driver for triode wired SE EL84, 6V6 or EL34
Thread Tools
Old Today, 05:47 PM   #471
euro21 is offline euro21  Hungary
If you compare -any of them- to 10k internal resistance, it's -almost- negligible ... but across this resistor flowing the filament current.
If it's not clean enough (or the environment not enough shielded), the hum/noise/RF (use exclusively non inductive resistor!) directly modulating the tube's bias.
The greater the resistance/impedance, the greater a modulation.
  Reply to this post
DHT driver for triode wired SE EL84, 6V6 or EL34Hide this!Advertise here!
Thread Tools
EL84 triode wired bias and operating points operater Tubes / Valves 5 23rd May 2020 08:02 AM
6L6 / EL34 / EL84 / 6V6 frequency response curves? diaz028 Tubes / Valves 100 12th March 2015 08:57 PM
Anyone try DHT 33 or 1Q5 Pentodes wired as Triode? rcollege Tubes / Valves 8 30th April 2014 10:19 PM
6L6-6V6-EL34-KT88-6CA7-EL84 Apex Jr Tubes / Valves 0 25th July 2012 09:44 PM
PSE UL EL84 or 6V6 or EL34? AudioGeek Tubes / Valves 6 9th March 2006 09:05 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
