Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
Thread Tools |
#51 |
Thank you.
#52 | |
Tried the ground out already on power amp no change :-( cost me Ģ500 for the work, I did get a new transformer installed I suppose.....found a fantastic supplier in the UK who made it to specification supplied from the ARC circuit for about Ģ90 delivered. I was thinking it might not sound like ARC spec product which was an absurd price for parts. I think it sounded better but hey it definitely did not wound worse :-) Transformer Equipment Ltd. | Sandwich Kent all voltages spot on. |
#53 | |
Mmmhhh, I see a mixed bag here. Good ideas, mixed with clearly visible problems. ![]() Good: those crocodile clips are maturing fine. Not a single Green one visible. Half are going through the yellow stage, fine. They are developing flavour. Half have reached mature Red sweetness, harvest them NOW, do not freeze them (Cryotreatment makes them stringy and bitter) , worst case keep them in the fridge for no more than 2 or 3 days. My Family loves them, they disappear within hours ![]() BAD ![]() You let 2 of them untouched for too long, now they turned BLACK!!! Do not even TRY to taste them, they will give you bellyache. Do not even feed them to your pets, they are UNSAFE by now. Wrap them in aluminum foil , even better in lead foil in case they turned radioactive, and dispose of them in a safe manner. GOOD: congratulations on your idea of wrapping caps tightly together with rubber bands, that way the breaking in marginal field does not go to waste, but preconditions those nearby. This thread should be a stickie, chock full of useful Audio info. PS: Eric Claptonīs Layla works even better, because it was recorded on a Fender Champ. Gobs of single ended Tubyness.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969. |
#54 | |
Sadly, mine is a lowly silver face. ![]() PS.: yet another can of snakes: tone caps, carbon composition resistors, hemp cone, etc... You know what I mean if you're into the musical instrument stuff. Last edited by Zung; 3rd December 2020 at 05:04 PM. |
#55 |
Carbon resistors have their place. Of all the modern production resistors, they're the least like an ideal resistor, their resistance generally rises with frequency. This flaw can be a virtue - in a RC circuit it adds an increasing cutoff as frequency increases. This can be quite useful for dampening high frequency interference, radio pick-up, and other RFI effects. Plus, it's just cheaper than an inductor or ferrite bead plus resistor, and manufacturers are concerned about pennies that add up.
Hemp cones? Every cone material (and shape) is different (stiffness, weight, internal dampening) and will affect the sound. How and how much is debatable. Instruments can be finicky things and are a sum of all the parts, plus usually for instruments like guitar, distortion is preferred rather than avoided. And musicians are a VERY subjective breed, often prone to emotionalizing rather than rationalizing (I'm the engineer in a family of musicians).
"if Im going to have something done poorly, Id rather not be paying professional wages to someone to do it." -anchorman |
#56 |
I bought an Eminence Cannabis Rex (hemp cone) on a whim, just because I thought the name is cool. Now I'm monogamously in love with it and wouldn't play anything else. And I still think the name is cool.
#57 |
Well, in this particular case there is solid Physics justification, besides any psycho-logical or psycho-enhancing overtones
![]() Big way, itīs nothing subtle. Hemp fiber is *strong* and hemp fiber based ropes and cords are still much in use, 6 times as strong as cotton fiber, let alone wood fiber which is smashed, boiled and blanched while being turned into a paste, so any paper incorporating it will be way stronger, more rigid and as a side note, better self damped, so cone response will vary a lot. Personally I donīt much like hemp cones for guitar (except, maybe Jazz Guitar) because to my ears itīs darker sounding. But there measurements match perceptions ![]()
#58 |
But Billy Gibbons, Carlos Santana et al do. Of course, they have the $$$ and can afford the Tone Tubby. I have to make do with a licensed copy.
#59 |
And they also had mirror-polished resistive element, didn't they? I remember ripping out one of these from a pre-war Telefunken radio.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
NOBLE diecast 20K Stereo potentiometer - very best quality pot! | cathodes | Swap Meet | 3 | 22nd October 2018 09:41 PM |
"Quality-feel" volume potentiometer | Plecto | Parts | 8 | 16th September 2014 11:09 PM |
Quality Control differences = variations in sound quality? | KT | Class D | 3 | 4th June 2014 01:02 AM |
Level-dependend Sound Quality by certainly Bass Drivers - very bad sound at low level | tiefbassuebertr | Subwoofers | 11 | 3rd March 2012 11:54 AM |
Level-dependend Sound Quality by certainly Bass Drivers - very bad sound at low level | tiefbassuebertr | Multi-Way | 1 | 2nd April 2010 05:12 AM |
New To Site? | Need Help? |
