Advice on first RH84 build - are these transformers suitable?
Thread Tools
Old 5th December 2020, 03:09 PM   #21
Ketje is offline Ketje  Belgium
Ketje's Avatar
That 310V can't be right.I don't see a drop to 200V to get the voltages from the schematic.More over, the selenium rectifier is for max 250V~ input.
Mona
Old 5th December 2020, 03:14 PM   #22
Eli Duttman is online now Eli Duttman  United States
A different transformer than the 1 in the schematics you've perused?
Eli D.
Old 5th December 2020, 05:30 PM   #23
Ketje's Avatar
Perhaps, but then also another rectifier.
Not a B250C125 but B300C125 !
Mona
Old 5th December 2020, 07:54 PM   #24
Certainly 4X UF4007s or other low noise/high PIV type at build time.
Eli D.
Old 6th December 2020, 10:12 AM   #25
Ketje's Avatar
Other diodes is a allways possible but that's not the point.
The 300V measured is not correct or the transformer is not the one in the schematic.
Mona
Old 14th December 2020, 05:39 PM   #26
slave2music is offline slave2music
Thanks all for your feedback. Given the simplicity of the RH84 design and the importance of component quality have decided to order the transformers required per the spec. Have given up trying to make a 'square peg fit into a round hole' with the recycled transformers.
I'm sure will be reaching out for help with the build once the BoM arrives.
  Reply to this post
Advice on first RH84 build - are these transformers suitable?Hide this!Advertise here!
Thread Tools
Can I make RH84 from these parts ? Hiten Tubes / Valves 27 31st October 2020 03:50 PM
RH84 SE, pentode driver... advice please bigjppop Tubes / Valves 148 17th April 2014 06:42 PM
My RH84 Build - first amp after a 25 year break -:) prelius Tubes / Valves 4 9th June 2011 02:58 AM
First post, first project RH84 Dingleberryefxs Tubes / Valves 4 17th July 2009 11:20 AM
Are these transformers suitable? NewVintageNut Chip Amps 12 24th September 2004 07:54 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
