Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
Thread Tools |
#31 |
Does the "output cap" have to be as large as 470uF?
Regards Åke |
#32 |
Spreading triode love.
No.
You chose the size based on the load you will drive and the LF response you want. If you use it as a line stage, it could be as small as 1uF if you're using it to drive a tube amp. I chose 470uF because they are common and give a good LF response on 32R headphones. If I was making one for just my ATH-R70x (470R) I'd use a 47u film cap only. Koda
If you can't learn to do something well, learn how to enjoy doing it poorly. |
#33 |
No Morse
-3dB frequency is = 1/(2πRC). So the lower impedance your headphones are the bigger the capacitor needs to be
#34 |
Yup so for 32R headphones it's a crappy -3 of 10Hz but for the 470R headphones I use normally, it drops to 0.7Hz
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
6C19/6N6/6F2 - proceeds to DIYAudio website | moggi1964 | Swap Meet | 0 | 15th February 2014 04:44 PM |
6N2, 6N6, 6N11 - Please help a beginner! (long) | horace | Tubes / Valves | 41 | 27th November 2013 08:19 PM |
In stock pcb for JHL 1969/PASS F5/NAP140/6N3 PRE-AMP/JHL headphone | diyhifishop | Vendor's Bazaar | 6 | 29th August 2012 08:48 AM |
looking for 6N6 and 6H30 | Gluca | Swap Meet | 0 | 9th May 2011 02:24 AM |
New To Site? | Need Help? |
