6N3/6N6 headphone amp using PCB.
Thread Tools
Old 21st May 2021, 04:12 PM   #221
JoeAlders is offline JoeAlders  Netherlands
Originally Posted by baudouin0 View Post
Actually just about anything will work! The more open loop gain you have there the lower the distortion should be but the distortion is quite low already.
You are absolutely correct!
Old 21st May 2021, 04:50 PM   #222
Ryssen is online now Ryssen  Sweden
Ryssen's Avatar
Originally Posted by JoeAlders View Post
I use the ECC99 as first stage. A very fine tube.
Have you changed anything in the first stage?
I thought of trying 6CG7 in the first stage....
Regards Åke
Old 21st May 2021, 06:35 PM   #223
kodabmx is online now kodabmx  Canada
Spreading triode love.
kodabmx's Avatar
6CG7 first stage I'd use 470R instead of 240R but it'll work if you just plug it in...
I offer circuit boards, kits, and complete systems for DIY vacuum tube audio.
Old 22nd May 2021, 09:45 AM   #224
Ryssen's Avatar
I tried 6cg7 but i think 6n2 has bettet bas so I swircheb back.
Tubes diesel have a stund.......
Regards Åke
Old 24th May 2021, 10:53 PM   #225
Ryssen's Avatar
I just wanna say that Its sounding great DEEEP bass great attack and nice highs.
With my Philips headphones.
I´m preparied to say that its the best heaadamp I`ve built.that is 4 peaces..
Regards Åke
Old 25th May 2021, 01:44 AM   #226
Francois G is offline Francois G  United States
Congratulations!
Just to be sure, did you stick with the schematic you posted in #213? Did you use the OP’s (kodaBMX) PCB to build it?
Thanks,
Francois
Old 25th May 2021, 07:05 AM   #227
Ryssen's Avatar
Yes its that schema Ecxept I use 6N2P and ecc99 and R1 100 ohm.
And I built it per to per,no pcb.
Regards Åke
Old 10th June 2021, 08:29 PM   #228
dl3it is offline dl3it  Germany
Default "theCarefulApproach"
I carefully studied this thread and decided to start my first design with tubes. In my brain work transistors, so please, be patient with me
I intend to build a headphone amp for loads from 32R - 600R. The idea with the WCF gave good results in the sim, and for the lower impedances, I decided to use an EDCOR WSM 600/150. High impedance devices will be connected directly...
Volume control will be done in the preamp. It's designed to accept 1Vrms as max input, with max. 3.8Vrms output @300R load.
I already have some 6N3P-EV and 6N6P-EV in my hands and plan to start with them.
Before I go into layout, fell free to give me any comments.
Old 10th June 2021, 09:14 PM   #229
Ryssen's Avatar
I think mine drives 32 ohms HP fine without transformer.
Regards Åke
Old 10th June 2021, 09:45 PM   #230
I've chosen the transformer mainly to have it and to play with it. I never used transformers in audio circuits and this is a nice playground for all kind of new "experiences".
In the simulation, driving 32R was no problem... But the THD results were significantly better with the transformer for low impedance HPs; that's why I decided to be prepared... I'm pretty much aware that the sim is something different than the real circuit; but it will be interesting to see, where to find the main differences.
Btw, I corrected the CCS
Last edited by dl3it; 10th June 2021 at 10:03 PM. Reason: attach correct schematic
6N3/6N6 headphone amp using PCB.Hide this!Advertise here!
Thread Tools
6C19/6N6/6F2 - proceeds to DIYAudio website moggi1964 Swap Meet 0 15th February 2014 03:44 PM
6N2, 6N6, 6N11 - Please help a beginner! (long) horace Tubes / Valves 41 27th November 2013 07:19 PM
In stock pcb for JHL 1969/PASS F5/NAP140/6N3 PRE-AMP/JHL headphone diyhifishop Vendor's Bazaar 6 29th August 2012 07:48 AM
looking for 6N6 and 6H30 Gluca Swap Meet 0 9th May 2011 01:24 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
