6N3/6N6 headphone amp using PCB.
Thread Tools
Old 12th May 2021, 06:23 PM   #201
JoeAlders is offline JoeAlders  Netherlands
Originally Posted by Ryssen View Post
Its this one,ecxept the cathode resistors are now 182 ohms.
Is that first cathode resistor 182 Ohm? Because that first stage is then on 1.7 mA only.
Old 12th May 2021, 06:30 PM   #202
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Yes
Regards Åke
Old 12th May 2021, 06:44 PM   #203
When I am running your diagram in LTspice and doing an analysis I get DC voltage at the common point cathode top tube and plate bottom tube of the 6N6 triodes around 59.5V which I find low. Isn't it better to get there around halve the supply voltage. (=280V)?
But perhaps I do not have the correct 6N6 models.
Old 12th May 2021, 07:01 PM   #204
What also puzzle me is that you are using 6N6 triodes, which can handle at least 4 W plate dissipation. So what is in fact the problem with your original design with 280V supply?
Old 12th May 2021, 07:10 PM   #205
Ryssen's Avatar
Do you have a model for ECC99 wich I use?
Regards Åke
Old 12th May 2021, 07:31 PM   #206
Yes I do. I will run your diagram using the ECC99 in the output stage (White Cathode Follower) and look at the results. Will let you know tomorrow.
Joe.
Old 12th May 2021, 09:31 PM   #207
Ryssen's Avatar
I think I founde the error...
R12 is connekted at the wrong side of c4,so the grid gets no ground potential....
I will fix it tomorrow.
Regards Åke
Old 13th May 2021, 02:37 AM   #208
kodabmx is offline kodabmx  Canada
Spreading triode love.
kodabmx's Avatar
Thought so.
I offer circuit boards, kits, and complete systems for DIY vacuum tube audio.
Old 13th May 2021, 09:36 PM   #209
Ryssen's Avatar
It´s working now.no I am under 5W/tube.
But now I am beginning to understand the importance of using matched tubes....
Regards Åke
Old 14th May 2021, 05:41 AM   #210
baudouin0 is offline baudouin0
IF you change R1 from 82R to 100R that will reduce the current. The tubes don't need matching for WCF. I would be surprised if the ECC99 and 6N6P should different with the linearity of the circuit - tubes don't really have a sound.
6N3/6N6 headphone amp using PCB.Hide this!Advertise here!
Thread Tools
6C19/6N6/6F2 - proceeds to DIYAudio website moggi1964 Swap Meet 0 15th February 2014 03:44 PM
6N2, 6N6, 6N11 - Please help a beginner! (long) horace Tubes / Valves 41 27th November 2013 07:19 PM
In stock pcb for JHL 1969/PASS F5/NAP140/6N3 PRE-AMP/JHL headphone diyhifishop Vendor's Bazaar 6 29th August 2012 07:48 AM
looking for 6N6 and 6H30 Gluca Swap Meet 0 9th May 2011 01:24 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
