Eliminate tube output transformer for Electrostatic speakerssp
Thread Tools
Old 23rd November 2020, 03:35 PM   #31
daanve is offline daanve  Netherlands
Originally Posted by Nikolas Ojala View Post
Winding a 1:1 transformer would be simple using a bifilar winding. Inductive coupling would be near perfection. Parasitic capacitance is one thing to worry about. It depends on how you fill the bobbin. There will be parasitic capacitances series connected. If you had many small capacitances in series that would be better than small number of big capacitances series connected. Multi section bobbins may help. Wind one section full, then continue to the next, etc.
No.
Inductive coupling is through the transformer core; bifilar winding does not change that.
Parasitic capacitance is typically not something to worry about when winding bifilar; on the other hand: it's your friend!
Good high frequency bandwidth is possible because of capacitive coupling which bifilar winding provides. But it only works that well with 1:1 ratio.
  Reply to this post
Eliminate tube output transformer for Electrostatic speakersspHide this!Advertise here!
Thread Tools
Best way to eliminate DC voltage at my DAC output? robbbby Digital Source 36 13th March 2014 06:57 AM
How to eliminate the "white noise" for the 300B tube amp? Angelpat Tubes / Valves 13 24th February 2011 08:57 AM
Freeware Program To Eliminate Hum From Wav Files? kelticwizard Everything Else 4 3rd April 2003 04:22 AM
Eliminate Member Rankings And Post Count kelticwizard Everything Else 163 11th January 2003 03:17 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
