Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
Thread Tools |
#21 |
Pfft, pico Farad strays and nano Farad cap values.
#22 |
Regarding the H-K chassis in the first post, it's not that complicated if you don't let it be overwhelming. Circuit by circuit, it's straightforward. The original mfr cannot spend the time and expense on aesthetics that no one will see.
How do you eat an elephant? |
#23 |
"Regarding the H-K chassis in the first post, it's not that complicated if you don't let it be overwhelming. Circuit by circuit, it's straightforward. The original mfr cannot spend the time and expense on aesthetics that no one will see."
Except for the repair engineer .. ![]() But you are right I think. The average consumer would never take a look inside the chassis. |
#24 |
There are many reasons for the pro's companies of those tube stone ages to establish a more structured, more repair friendly style. Time is money for the pro's. Best is to have gear or cards that are easily changeable in case of an emergency. Amps in magazines for example.
#25 | |
This picture is interesting. What is this for amplifier(?) ? And ... "those tube stone ages" ? Absolutely not ! Alive and kicking!! Last edited by JoeAlders; 21st November 2020 at 07:52 PM. |
#26 |
One wonders what kind of failure rates they were seeing on those mass-produced point-to-point wired consoles and amps. At least I find it hard to believe that all units produced worked straight off the assembly line.
Tom
Modulus-86, 186, 286, & 686: 40-240W (8Ω), <-120dB THD. HP-2 Headphone Amp: 660mW, <-130dB THD. Taming the LM3886. Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right |
#27 |
Point to point I made over 10 years ago. 6L6GC SE, tube rectifier, OA2 voltage regulation, ECC81 driver.
#28 |
AmadeusMozart,
Great layout, great planning, and lovely wiring! What were the output tube types? I hope you are still using that as one of your most listened to amplifiers. I only put 1 handle on my amplifiers; your 2 handles are more symmetrical. |
#29 | |
Very low failure rate - on average I managed less than 3 cosmetic faults on 19K solder points while working for Philips putting telephone exchanges together. Components were tested before use. |
#30 |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Anyone use magnet wire for point to point wiring projects? | Hybrid fourdoor | Parts | 10 | 2nd February 2004 09:11 AM |
Audio Note's Kit One done in point-to-point wiring | Wram | Tubes / Valves | 18 | 29th April 2003 11:59 PM |
Point-to-point .... I hope there's a point | RobPhill33 | Pass Labs | 9 | 14th January 2003 04:14 PM |
Point to Point wiring | HarryHaller | Everything Else | 79 | 22nd March 2002 12:15 AM |
point to point wiring | diy student | Solid State | 8 | 24th September 2001 02:56 AM |
New To Site? | Need Help? |
