Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
Thread Tools |
#31 |
Type 27?
#32 | |
Sin Bin
#33 |
No worries Felipe. I think you may want to be a bit more careful and perform more research and tests before drawing to a conclusion that the 2 components “sound bad”. It gives the wrong impression which frankly isn’t useful when the issues could be anywhere in your system.
If you want lower gain, the 71a is a great valve to look for. Cheers Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp) http://www.bartola.co.uk/valves/ |
#34 |
Sin Bin
I know very well the 2 components, I was really surprised that using the 2 components togheter sounded bad because the 2 components are top notch SQ, so I was asking help to know what's happening. Thanks for 71a suggestion.
#35 |
You have a fundamental fallacy.
Two individually good module (NOT component!) cooperation depends on good planning and implementation. It's not "plug and play", it's requiring proper planning. Each module output has an impact to other input, thus can change its operation, and vice versa, the parameters changing reacts module components. If you look a gyrator as "module" and tube as "module", not cooperating component conglomerations, the final operation may be uncertain. |
#36 |
Sin Bin
Ale followed your advice: no bypass cathode capacitor and no SSHV2. I'm making a new one SSHV2 because I suspect is damaged.
#37 |
Sin Bin
Well all is going OK with a new power transformer with more voltage.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
GB for Salas SSHV2 regulator | Tea-Bag | Group Buys | 802 | 24th October 2020 09:11 PM |
Broskie BCF PCB and Salas SSHV2 kit | nautibuoy | Swap Meet | 1 | 23rd June 2017 09:50 AM |
FS: Salas SSHV2 regulators complete, used | 50AE | Swap Meet | 3 | 14th December 2015 11:36 AM |
FS: 4x Salas SSHV2 regulator complete kits (boards, resistors and transistors) | regiregi22 | Swap Meet | 12 | 3rd January 2014 10:59 AM |
WTB: Salas SSHV2 reg | tubesguy | Swap Meet | 15 | 12th December 2012 02:06 AM |
New To Site? | Need Help? |
