Salas SSHV2 + Moglia hybrid mu-follower
Thread Tools
Old 18th November 2020, 05:49 PM   #11
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
Hi Felipe
Personally I think is a complete waste of a shunt regulator to be placed in front of the hybrid mu-follower. You have already a very high PSRR with the cascode MOSFET in the gyrator board. No point, at all.
It looks like you may have some oscillation playing around. I notice you have no HT decoupling between the SSHV2 and the input (MOSFET drain) of the gyrator. Bad combination due to the high impedance of the gyrator presented to the SSHV. You may want to try a 100uF cap plus a stacked film 100nF right at the +B and -B connections of the gyrator PCB to see if that's the cause of your audio degradation.
Otherwise hard to follow without sniffing with the right tooling....
Hope this helps
Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 18th November 2020, 05:57 PM   #12
merlin el mago is offline merlin el mago  Europe
Sin Bin
Hi Ale,
Once yours hybrid mu-follower warm up the russian teflon cap sounds very very good, no lack of bass like a the beginning. I used also a 100uF + 100R at the B+ without good success because the SQ decreased. Now I'm using only your hybrid mu-follower like for the 26.
Cheers
Felipe
Old 18th November 2020, 05:59 PM   #13
euro21 is offline euro21  Hungary
1 st. : why did you omitted the grid stopper in preamp?
in gyrator
C1:
R7:
Desired operating point of 5687: Ua, -Vg, Ia
Preamp anode current (voltage on 10R in gyrator, voltage on 470R in preamp):
Anode voltage:
p.s. I agree with Ale. Without SSHV2 the preamp should work.
p.s.2 the 17V margin on SSHV2 CCS is very low.
Old 18th November 2020, 06:01 PM   #14
mogliaa's Avatar
Originally Posted by merlin el mago View Post
Hi Ale,
Cheers
Felipe
Hi Felipe
the gyrator doesn't change with "warm-up" time. It's pretty stable from a tempco point of view. I have not noticed any changes over time am afraid.
Perhaps is something else in your system. I'd also suggest trying without the cathode bypass capacitor, it will sound better in my view....
Cheers
Ale
Old 18th November 2020, 06:11 PM   #15
Sin Bin
Ale the Russian teflon caps were new when the lack of bass, now both hybrid mu-followers are sounding with high SQ. The cathode bypass capacitor adds bass so more clear without cap (I tried) thanks.
Old 18th November 2020, 06:17 PM   #16
mcandmar is offline mcandmar  Ireland
mcandmar's Avatar
SSHV2 -> Gyrator works great for me. Overkill, yes.
The voltage drop across your SSHV2 is way too low at 15.6volts. The instructions call for 20v drop across the regulator, but in testing i found it needed more like 35v to work properly while sinking 27ma.
My final implementation has 50v across is, 200v in -> 150v out into the Gyrator for a 01A tube.
Old 18th November 2020, 06:21 PM   #17
Sin Bin
Because it uses a small solid copper core wounds
in gyrator
C1: 220nF
R7:470R
Desired operating point of 5687: Ua ~130-140V, -Vg -6V, Ia 12mA
Preamp anode current (voltage on 10R in gyrator 12mA, voltage on 470R in preamp~5-6V):
Anode voltage: ~140-150V
The SSHV2 CCS is set to 50mA.
Old 18th November 2020, 06:21 PM   #18
mogliaa's Avatar
Good point and well spotted. The SSHV2 CCS is cascoded and will benefit from +25V for best HF performance.
Old 18th November 2020, 07:50 PM   #19
You have a nice bump at about 2Hz, due to the C2-R6-C1 interaction, so there are the reason of "lifeless".
Try much smaller C2, for example 47nF.
BTW why did you choose the 5687?
It's super driver tube, but in this situation has too much gain (more than 24dB).
Old 18th November 2020, 07:56 PM   #20
Sin Bin
R6 Ale's schematic is 10M not 4.7M
Good question: "BTW why did you choose the 5687?"
You have reason Bela have too much gain but sounds very good, isn't a preamp, it's the analog output amp of the noDac, with something half power or less will be good, I have 4P1L but it's really expensive the PSU & the comments about the sound it's not my cup of tea.
Wow output total THD 0.04%
Could you simulate with 0.5VAC of input, thanks?
Salas SSHV2 + Moglia hybrid mu-followerHide this!Advertise here!
Thread Tools
GB for Salas SSHV2 regulator Tea-Bag Group Buys 802 24th October 2020 09:11 PM
Broskie BCF PCB and Salas SSHV2 kit nautibuoy Swap Meet 1 23rd June 2017 09:50 AM
FS: Salas SSHV2 regulators complete, used 50AE Swap Meet 3 14th December 2015 11:36 AM
FS: 4x Salas SSHV2 regulator complete kits (boards, resistors and transistors) regiregi22 Swap Meet 12 3rd January 2014 10:59 AM
WTB: Salas SSHV2 reg tubesguy Swap Meet 15 12th December 2012 02:06 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
