Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
Thread Tools |
#101 |
I might leave the UL out for now, as it it's going to be challenging atm.
#102 | |
.SUBCKT E130L_T 1 2 3 ; Plate Grid Cathode + PARAMS: CCG=35P CGP=2P CCP=17P RGI=2000 + MU=7.602 KG1=390.0 KP=60.0 + KVB=14.625 VCT=0.168 EX=1.806 * Vp_MAX=250.0 Ip_MAX=0.7 * Vg_step=2.0 Vg_start=0.0 Vg_count=10.0 *---------------------------------------------------------------------------------- E1 7 0 VALUE={V(1,3)/KP*LOG(1+EXP(KP*(1/MU+(VCT+V(2,3))/SQRT(KVB+V(1,3)*V(1,3)))))} RE1 7 0 1G ; TO AVOID FLOATING NODES G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1} RCP 1 3 1G ; TO AVOID FLOATING NODES C1 2 3 {CCG} ; CATHODE-GRID C2 2 1 {CGP} ; GRID=PLATE C3 1 3 {CCP} ; CATHODE-PLATE D3 5 3 DX ; POSITIVE GRID CURRENT R1 2 5 {RGI} ; POSITIVE GRID CURRENT .MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N) .ENDS |
#103 |
[QUOTE=Koonw;6423842]Two more snapshots, 250V and 300V HT version, hope these help in your project. If you want the sim asc let me know.[/Q
the only difference here is that I have 1.6k impedance transformers, (which is what philips recommend) with UL tap (43%). |
#104 |
#105 |
You save the file and then open with LTSpice, make sure it has .asc and not .txt extension.
#106 | |
The grid current in the model file is controlled by value of IGA, IGB and IGC which can be adjusted to match grid current curve. But Paint tool allows you to do repaint it by pasting the model files into "Model" and then "Update", this is how all my models are updated. |
#107 | |
[QUOTE=frentec;6424452]
Yes why, that make a lot of difference to triode power output. With 1k6 250V the output power becomes more even among the mode. I leave 300V version for you to work on then. |
#108 |
I wrongly put in last attachment here is the correction for 250V, 1k6 OT:
Pentode out 21V sg_ampl=12V, Thd 5.3% @27.5W Pout UL out 16V sg_ampl =23.5V, Thd 1.38% @16W Pout Triode out 21V sg_ampl=23.5V, Thd 1.37% @27.5W Pout |
#109 |
Thank you kwoon, you’re a diamond
#110 |
Please note that triode PP with 1k6 load at that operating point will exceed the anode dissipation limit. E130Ls (or other top cap output tubes) will turn gassy with excessive anode dissipation.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
E130L in Triode mode | gorgon53 | Tubes / Valves | 52 | 18th November 2020 09:32 AM |
E130L triode | pieroh | Tubes / Valves | 2 | 18th March 2019 02:59 AM |
E130L / 7534 tubes. | brommermartin | Swap Meet | 1 | 18th October 2017 07:22 AM |
E130L Micron | azazello | Tubes / Valves | 31 | 13th March 2014 10:05 AM |
E130L SE again | Hojvaelde | Tubes / Valves | 1 | 24th January 2011 02:35 PM |
New To Site? | Need Help? |
