Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
Thread Tools |
#21 |
The Triad N-77U is not available in my country: Due to government regulations, Mouser is unable to sell this product in your country. I get your point though.
@Eli: I appreciate your list of amps. Now I can search more focussed. However... Could you point me to the best info w.r.t. el Cheapo? I read you were involved. It is not that easy to find concise info about it on the internet. |
#22 | |
#23 |
Generally, headphones on your ears are many times more sensitive, versus loudspeakers.
I often ask why HI Fi Stereo manufacturers do what they do. Lack of knowledge. Average customer base that is fairly easily satisfied. Customer's speaker efficiency, distance to listener, room size and absorbent items, etc. Price to a Point (save money, more profit) Think of your own reasons that they act that way. I try very hard to reduce the hum and noise on my amplifiers. Almost all of them have less than 100uV at the output; I use them with medium efficiency loudspeakers that are only 2 or 3 feet away from me. But . . . I do not consider my amplifiers to be good enough for most headphones . . . Unless the output is sent to a resistor load, plus a pair of resistors to attenuate what goes to the headphones. That way, you turn the volume up a little, and the signal level, versus the hum and noise level is improved (good enough for almost all systems). In the 50s and early 60s, the accepted way to get a good Hi Fi Stereo, was to tie together a number of individual specialized products into what was called a 'component system'. Many thought that all of the individual components were compatible with each other; not always true. Now, in 2020, so many think they can tie a number of products together, and get what thay want. Again, that is not always true. A system is complex, involves signal voltage levels, magnetic pickup of nearby fields (like a magnetic cartridge and a turntable motor, or placing it on top of a power amplifier), gain, input and output impedances, speaker efficiency, room size, music selection, what volume is desired, etc. One of the most important ways to get a system that satisfies, is to completely and accurately describe both the wants and needs of such a system. Without that, it is like shooting an arrow, blindfolded, in the dark, at an unknown target (the target is 'safe' it hardly ever gets hit). Many a dollar has been $pent on all kinds of gear, that is then replaced with other gear, and never satisfies. That is because of two things: The target was never hit. Some are never satisfied. Listen to the Music. Do not listen to the sound of the system. Enjoy the music. Then you might like the system. Last edited by 6A3sUMMER; 15th November 2020 at 10:50 PM. |
#24 |
The method employed by Hegeman and others was used in "El Cheapo" (schematic provided). The LC reservoir section is critical to high performance. A refinement is inserting a LC "hash" filter made from a high current RF choke and a 1000 pF. mica or high quality ceramic (NP0/C0G) cap. between the doubler stack and the reservoir section.
Large valued caps. at the I/P of a PSU filter "crush" the ripple fundamental, but they generate ripple overtones up into the RF range in doing so. (TANSTAAFL strikes again) I've discussed the mechanism many times both here and AA. A "hash" filter keeps the trash out of the ultimate PSU product.
Eli D. |
#25 | |
#26 |
Eli,
Of course that schematic of El Cheapo is a good power supply . . . Using 3 separate power transformers is sometimes considered a luxury. More real estate, weight . . . and expensive. 1 B+, and 2 separate filament transformers. That helps to isolate the noise from one power supply getting into another supply (has to cross from the 1st secondary, to the 1st primary; and then onto a 2nd primary, back to a 2nd secondary. Last edited by 6A3sUMMER; 16th November 2020 at 06:07 AM. |
#27 |
Believe it or not, 3 transformers were (sic) the inexpensive route.
![]() Things change over time. Anybody in North America considering an "El Cheapo" build can get a complete set of power "iron" from Allied Electronics. Stock # 70218190 = main B+ $32.59 Stock # 70218344 = 2 "12" VAC windings for B+ boost and heater power. $16.73 Stock # 70009000 = B- feed and 12AT7 heater power. $16.83 Stock # 70218145 = B+ filter choke $8.62 Approx. $75 for a reasonably sophisticated set of power "iron" is (IMO) a pretty good deal. FWIW, Triode Electronics charges approx. $100 for a ST-35 power trafo and that chunk of "iron" will not completely satisfy the needs of an "El Cheapo". Something additional is provided to show the versatility of the Triad isolation transformers. ![]()
Eli D. |
#28 |
So the only expen$ive thing about the EL Cheapo having 3 transformers . . .
is the extra large chassis to be able to fit those on. 1 transformer = more hum and noise cross coupling; but a smaller chassis. 3 transformers, and 2 output transformers that need to be spaced away from them = a larger chassis. Tradeoffs. |
#29 |
The N-77U is pretty good sized, but the B- trafo and twin "12" VAC items are not especially large.
Consider mounting some power "iron" item on the side wall.
Eli D. |
#30 |
Artosolo lade this suggestion for a power transformer on another thread ...
tsl180_001/transformers-with-fastening/indel/tsl-180-001/ For €57 it has lots of versatility. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
F5 Turbo v2 Stereo Amp Illustrated Build (my first amp build) | chuckd | Pass Labs | 16 | 28th August 2020 12:45 AM |
Super Squirrel Monkey - First from-scratch tube amp build, first guitar amp build | ericj | Instruments and Amps | 33 | 22nd June 2020 08:26 AM |
3-way build Advice (first build) | crumdev | Multi-Way | 12 | 17th March 2017 01:04 AM |
First Build (Stereo LM3886) in need of psu advice | Megadeth | Power Supplies | 30 | 7th March 2013 09:18 AM |
New To Site? | Need Help? |
