Current-drive by a valve amplifier
View Poll Results: What do you think about the SEP current-drive idea?
Brilliant idea 2 16.67%
May be good but not exactly this way 2 16.67%
Bad idea 3 25.00%
I don't know / no opinion 5 41.67%
Voters: 12. You may not vote on this poll
Thread Tools
Old 3rd December 2020, 03:03 AM   #91
Wavebourn is offline Wavebourn  United States
Wavebourn's Avatar
Originally Posted by 6A3sUMMER View Post
“Those who do not know history, are not aware that we are 'in' Deja Vu.
It is even better to learn the theory in depth, and solve math problems for themselves, than pretending to be a guru while learning, opening topics inviting to discuss opinions about Ohm law implementations
!!!Warning!!!
Single Ended Class-A-Holism is addictive!!!
Old 3rd December 2020, 04:47 AM   #92
6A3sUMMER is offline 6A3sUMMER  United States
"Poll: What do you think about the SEP current-drive idea?"
Before answering this poll, I want to be sure about what an SEP is.
I think that Three Letter Acronyms are confusing (TLA).
When is a TLA not a Three Letter Acronym?
When it is a Thirty Letter Acronym.
Now back to the SEP . . .
Is that a Single Ended Pentode?
Just wanted to be sure.
Thanks!
Still having doubts . . .
I always thought that AMA meant American Medical Association.
Then I learned about AMA, the American Management Association.
Now, I see Slang on the internet, it says:
AMA is "Ask Me Anything" or "Against Medical Advice"
I try to write out 'Output Transformer' instead of 'OPT'.
And many other similar things, to avoid Three Letter Acronyms.
Newbies are trying to learn.
Just my opinions.
"Vote Early, and Vote Often" Deja Vu for the youngsters who were not alive then.
Old 3rd December 2020, 06:27 AM   #93
NickKUK is offline NickKUK
As a very nieve beginner view - in my book the tube is a current device.. only resistance gives it a change in voltage.
Sure an OTL driving a low impedance is a current drive (tongue in cheek) - typically the intermediate steps use voltage amplification due to the grids.
If you used an inverted triode, then used that to drive the grids for the next stage? An inverted-triode OTL is a simply a current drive but todo it properly the B+ needs to run through the end load.
All the 'current drive' in the pictures is doing is causing a feedback loop with additional gain needed that then causes a higher current? No real difference when using feedback to lower output impedance for driving low impedance loads.
Just beginner thoughts..
Old 3rd December 2020, 06:12 PM   #94
Nikolas Ojala is offline Nikolas Ojala  Finland
Nikolas Ojala's Avatar
Arrow Single-ended indeed
Yes.
High-order harmonics are more offensive than low.
— D.E.L. Shorter: "The Influence of High-Order Products in Non-Linear Distortion". Electronic Engineering, April 1950.
Old 3rd December 2020, 10:48 PM   #95
Use the 2nd harmonic distortion of a single ended pentode amplifier to partially cancel the 2nd harmonic distortion of a loudspeaker driver.
One is long on the positive alternation, and short on the negative alternation.
The other is long on the negative alternation, and short on the positive alternation.
We tried that experiment with a DPDT phase reversal switch, a single ended 2A3 DHT amplifier, and a Spica tc 50 loudspeaker.
It might be time to try it with a single ended pentode amplifier that has little or no negative feedback, and a loudspeaker.
Phase is everything if you want to try this. The DPDT might allow you to fairly easily hear the difference in tonality/timbre of the two switch settings.
Old 4th December 2020, 08:28 PM   #96
Wink 2nd harmonic, vanish now
Yes. I had almost forgot but thanks for reminding. Eduardo de Lima wrote about that in his article "Why single-ended tube amplifiers?"
The essential part of his conclusion:
The really good sonic performance of a well put together system using single ended amplifiers can be understood if we consider the whole system performance. A system made using single ended amplifiers is a perfectly valid way of achieving a very good sound also from the measurements point of view. We just have to measure the correct parameter. The output of the whole system.
One may use that wisdom with any amplifier and speaker combination. What you hear is what you get, and if you don't trust your ears, then use a microphone.
  Reply to this post
Current-drive by a valve amplifierHide this!Advertise here!
Thread Tools
Short wave Valve transmittor :) what valve is best? sco1t Everything Else 92 5th November 2017 10:52 AM
mix current drive with voltage drive at LF? capslock Solid State 56 15th October 2017 05:35 PM
Convert a non-valve amp to a Valve (tube) Amp seanthomas46 Instruments and Amps 17 20th April 2015 05:11 AM
Swap Shanling CD-T80 valve CD player for Quad valve equiment johnm Swap Meet 2 24th September 2009 01:15 PM
no current mirror, current mirror, cascoded current mirror, bjt or jfet VAS? maxpou Solid State 31 17th June 2008 05:31 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
