6P13S SE cheap amp: improvement suggestions
Thread Tools
Old 21st November 2020, 09:37 PM   #51
zintolo is offline zintolo  Italy
Update on this topic:
I've receipt the kit including tubes and transformers.
Old 21st November 2020, 11:00 PM   #52
Here the datasheet of the preamp tube: https://frank.pocnet.net/sheets/095/6/6N2.pdf
Looking at the curves of the output tube ( https://frank.pocnet.net/sheets/095/6/6P13P.pdf ) am I correct saying that I need around 60V on screens to hit g1=0 with a=50V with Ra=10k4 and working point at 300V 40mA?
I would like to connect a 8 Ohm speaker to the 4 Ohm tap, in order to get around 3 Wrms that should be handled by those small transformers.
A bit more can be obtained by working at 250V and 50mA with Ra=5k2 and hitting g1=0 at 50V and around 90 mA, but I think the output transformers would suffer.
In any case, the suggested voltage for the secondary voltage of the power supply seems a bit high to me (230 to 310 Vac means 310 to 420Vdc).
  Reply to this post
6P13S SE cheap amp: improvement suggestionsHide this!Advertise here!
Thread Tools
6P13S - WHAT TO DO WITH Tesla88 Tubes / Valves 2 4th September 2013 01:52 PM
suggestions for improvement (Old Consumer Amp) UMarcus Solid State 3 28th January 2012 08:24 AM
Cheap improvement Yonnat Pass Labs 10 22nd December 2003 01:46 AM
suggestions for improvement wintermute Solid State 12 10th September 2003 03:52 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
