Add step-up tx to 26 lineamp
Old 17th October 2020, 09:05 PM   #11
merlin el mago is offline merlin el mago  Europe
merlin el mago's Avatar
Originally Posted by analog_sa View Post
You should do some basic troubleshooting.
Play a 1kHz sine on the dac and measure the voltage across the 50ohm resistor. Connect transformer 300ohm primary to resistor with the secondary unloaded and take measurements at both primary and secondary windings. Add tube stage.
Can't do it see attached schematic of the output filter of the noDac I use.
Old 17th October 2020, 09:36 PM   #12
Oooops I forgot I use SET 5687 CCS loaded between the noDac & the 26, surely this is the guilty increasing the output impedance of noDac
Old 18th October 2020, 11:50 AM   #13
euro21 is offline euro21  Hungary
Try to check primary/secondary ratio (maybe it's 1:7).
Adding 1Veff (from 5687, for example at 1kHz) to lower side, on the other side the voltage must be 7V.
Repeating this, several times, at different frequencies (from 20Hz up to 50-100kHz) turns out if it is suitable for step up input transformer.
Old 18th October 2020, 03:08 PM   #14
SG 0.250Vrms, 50 ohms source impedance, without zobel.
20Hz 2.61
100Hz 4.8
1K 4.8
5K 2.56
10K 1.28
15K 0.75
20K 0.47
25K 0.3
30K 0.12
35K 0.05
40K 0.04
50K 0.04
55K 0.08
60K 0.036
70K 0.14
80K 0.32
90K 0.16
100K 0.039
Old 18th October 2020, 04:15 PM   #15
300R side have a center tap that measures the same between the center tap & the 150R of both sides
Freq. Ratio
20Hz 2.52
100Hz 5.72
1K 7.07
5K 1.78
10K 0.74
15K 0.37
20K 0.20
25K 0.063
30K 0.048
35K 0.032
40K 0.028
50K 0.048
55K 0.19
60K 0.12
70K 0.04
80K 0.04
90K 0.04
100K 0.036
Old 18th October 2020, 04:45 PM   #16
I have a couple of Edcor GXSE5-600-15K pri.15K sec.600R
Freq. Ratio
20Hz 1.15
100Hz 2.59
1K 4.68
5K 3.86
10K 2.96
15K 2.4
20K 2.04
25K 1.79
30K 1.59
35K 1.45
40K 1.35
50K 1.18
55K 1.08
60K 1
70K 0.86
80K 0.72
90K 0.64
100K 0.041
Edcor measures 24R & 258R
Old 18th October 2020, 05:18 PM   #17
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
That kind of clears it up.
You have nearly 1:5 @ 1kHz, the low frequencies are depressed because of high output impedance/low transformer inductance and the highs are depressed...dunno why really but a crappy transformer or a capacitive load seem both possible. How is the transformer loaded?
Old 18th October 2020, 08:57 PM   #18
Without load.
  Reply to this post
Add step-up tx to 26 lineampHide this!Advertise here!
Threshold NS10 Lineamp PCB apassgear Pass Labs 628 21st March 2019 07:01 PM
Lineamp merlin el mago Tubes / Valves 75 19th May 2011 06:16 PM
Need recomdations on a lineamp woody Tubes / Valves 27 4th August 2003 09:38 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
