Lifting centre tap for B+ delay
Old 16th September 2020, 09:20 PM   #11
6A3sUMMER is offline 6A3sUMMER  United States
He said: "(About 370v DC across it in standby)"
It = 10k 10 Watt.
I took him Literally.
Old 17th September 2020, 08:59 AM   #12
Ketje is offline Ketje  Belgium
Ketje's Avatar
It = 10k 10 Watt.
Well, he is right, at open circuit that is
Mona
Old 18th September 2020, 04:54 AM   #13
petertub is offline petertub  Sweden
petertub's Avatar
Originally Posted by hariadi88 View Post
If I have power trans with full wave rectifier, is it possible (and safe) to put switch between centre tap of secondary and ground to delay the B+?
I know ther is more proper B+ delay circuit out there, but I prefer the simplest one (albeit manual).
Any simpler way? Use Thermistor instead of switch?
Thanks in advance
Delaying B+ is overrated and might be damaging to the power tubes.
What do you want to solve with this ?
My home is at www.tubular-well.se
Old 18th September 2020, 06:23 AM   #14
hariadi88 is offline hariadi88  Australia
I saw the voltage at turn on goes up to 500V and settles down to 400V at the first cap (as intended) in 30 seconds or so. That exceed the capacitor rating of 450V, and I don't have higher rating capacitor.
Old 18th September 2020, 08:53 AM   #15
Get capacitors that are rated for 500V or more.
Some are rated for 550V surge and 500V operational.
You may have to stack capacitors in series, with leakage balancing resistors across each one. You need 2X the capacitance for each one.
Keep in mind, if the output tubes ever die, the B+ will rise to 500V, just like they do at start up.
To quote the capacitor . . . Ouch!
And ask yourself, what happens if you, or someone else forgets to put the standby switch in standby before powering on the amp?
  Reply to this post
Lifting centre tap for B+ delayHide this!Advertise here!
Ground lifting dac-i/v dreamth Digital Source 18 27th February 2020 09:27 AM
Use Centre-tapped transformer without using the centre tap...possible? Crom Power Supplies 11 6th December 2013 04:32 PM
Lifting Pads and Tip Temperature DreadPirate Construction Tips 7 12th June 2010 09:32 PM
lifting the earth Jaap Tubes / Valves 4 23rd November 2009 07:03 PM
Need help lifting pin glt Parts 3 23rd April 2009 09:51 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
