Votage doubler safety
Old 16th September 2020, 01:30 AM   #11
TonyTecson is offline TonyTecson  Philippines
diyAudio Moderator Emeritus
TonyTecson's Avatar
why not just use a simple voltage double and use the center voltage to supply the screens? i do that all the time.....i even use chokes at the center voltage tap where the two caps meet....
i try to avoid complicated situations as much as i can...
Old 16th September 2020, 01:32 AM   #12
TonyTecson's Avatar
Originally Posted by dgta View Post
Wait just a second.
The answer to that question is yes. But that's not what you have. You don't have "one secondary" and the "other secondary". You have one secondary with multiple taps. That's a different kettle of fish. You need to make sure it's properly designed and wired. As said, you have a short in there.
Make sure it's all correct and run a sim if in doubt. Otherwise things can go boom ouch.
yes, and he can learn it the hard way....i did once and never going there again..
Old 16th September 2020, 01:33 AM   #13
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
The "half-wave" doubler circuit could be used, or two, one from each tap. The "full wave" doubler shown can't share a common with anything else on the transformer.
Old 16th September 2020, 10:38 AM   #14
Eli Duttman is offline Eli Duttman  United States
Half wave multipliers have been mentioned. The half wave parallel topology works quite well, providing adequately large caps. are employed.
Eli D.
Old 16th September 2020, 03:05 PM   #15
Palustris is offline Palustris  United States
Palustris's Avatar
Thanks, that's what I suspected, I just wanted confirmation.
Old 16th September 2020, 03:18 PM   #16
gideon1990 is offline gideon1990  Netherlands
If it is just for the screen supply why don't you take an OD3 or other VR tube and feed that of your main B+? It'll be extremely stable
Old 16th September 2020, 03:51 PM   #17
dgta is offline dgta  United States
Here you go. Blue trace is a bit hard to see, around 340V
Old 16th September 2020, 05:11 PM   #18
Palustris's Avatar
With the current (external) power supply, I am using two OD3 off of the B+ and that works fine. I am building a new power supply for the amp with greater current capability and the second set of taps off the secondary was tempting me to use them.
The half wave doubler appears to be a practical approach.
Old 17th September 2020, 12:27 AM   #19
TonyTecson's Avatar
yes, this is how to do it...
  Reply to this post
Votage doubler safetyHide this!Advertise here!
Protecton Check DSP Votage Kik1 Audio Sector 1 10th March 2018 11:54 PM
No Bias Votage on 12AX7 Electrobumps Instruments and Amps 11 31st October 2015 06:54 PM
Input votage various rf sources peterlo Everything Else 4 25th June 2007 11:08 AM
high votage output stage latala Solid State 31 4th May 2006 12:18 PM
Can capacitors with different values and different votage Tony D. Solid State 5 5th October 2001 04:51 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
