Spark plug wire for tubes with a top cap?
Old 17th September 2020, 07:17 AM   #31
H713 is offline H713  United States
H713's Avatar
Depending on the voltages involved one also must consider corona damage to the insulation over time. Some materials take this better than others. IIRC, Teflon is quite good and PVC is quite poor.
Old 17th September 2020, 07:21 AM   #32
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
Originally Posted by lcsaszar View Post
One has to consider aging, too. Plastic insulators can become rigid and brittle after the plasticizer components evaporate after a couple of years. Heat and UV radiation will speed up this process. If you bend such cable, there will be cracks on it, and the conductor will be exposed.
Silicone is an exception, and teflon also (I think). I use a teflon insulated silver plated copper wire, pulled in a transparent teflon tube.
Also HDPE....
We don't rise to the level of our expectations, we fall to the level of our training
Archilochus
Old 17th September 2020, 05:50 PM   #33
k35kk is offline k35kk  United States
Default Another wire to try
Consider type DLO diesel locomotive wire. It's available as small as #14 gauge, with tinned conductors. 2000 volt insulation, with a jacket tougher than an old boot, proof against abrasion & petroleum products, yet flexible.
Old 17th September 2020, 06:31 PM   #34
wrenchone is offline wrenchone  United States
wrenchone's Avatar
I would not consider any thermoplastics for top cap wiring - this includes PVC and the various forms of polyethylene. The heat from the tube will accelerate their aging. Rubber test probe wire, though admirably limp, does not age very gracefully. The only things I would consider for top cap wiring insulation are PTFE and silicone. As far as voltage rating, I don't go crazy about it, but make sure that points of maximum voltage stress (like the chassis pass-through) are protected. I use a rubber grommet to provide insulation, strain relief, and abrasion resistance. I've seen silicone grommets floating around, but I usually use the standard black rubber grommets.
  Reply to this post
Spark plug wire for tubes with a top cap?Hide this!Advertise here!
Are 6L6 Metal tubes plug and play Duke58 Tubes / Valves 11 18th September 2020 11:42 PM
Polarize plug, 3 wire or keep as is Tommyboy60 Tubes / Valves 17 3rd June 2020 12:07 PM
FS: Dynaco ST70, RUby EL34 tubes, Biased, Plug&Play baco99 Swap Meet 2 10th May 2018 10:23 PM
240/300 Ohms balanced IEC FM-Plug for flat Dipole Wire and for Disass'y e. g.Quad FM3 tiefbassuebertr Analogue Source 13 4th July 2014 08:56 PM
Good wire and plug for DIY power cord lovemov Parts 0 19th December 2003 07:14 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
