Tube amps with tv tubes
Old 18th September 2020, 05:17 AM   #31
davorin is offline davorin  Croatia
Originally Posted by smoking-amp View Post
If you like EL506 ($ 600 Ebay), take a look at the 10JA5 Vertical Sweep ($3 Vacuumtubes.net)
Other than 1/3 the screen V, nearly the same tube.
7868 and 7591 are similar too. (and same screen V)
The Russian 6P41S works very well, if the G2 voltage is limited to half the anode.
The connection of the base (both tubes are MAGNOVAL) EL506 and 6P41S is the same!
Old 18th September 2020, 07:51 AM   #32
Glass_painter is offline Glass_painter  Israel
Default 6FM7 dissimilar triode
Hi
The 6fm7 is the compactron sister of 6em7.
The 6EM7 is getting costly in last few years hence the recommendation to look at 6FM7.
This is a vertical deflection amplifier and driver in a single bottle.
This is a very good sounding tube SE or PP, anode or cathode parafeed configuration - highly recommended.
BR
Glass painter
Old 18th September 2020, 10:58 PM   #33
smoking-amp is offline smoking-amp  United States
smoking-amp's Avatar
There is also 6GF7 and heater V variants.
Old 18th September 2020, 11:29 PM   #34
TonyTecson is offline TonyTecson  Philippines
diyAudio Moderator Emeritus
TonyTecson's Avatar
we shouldn't be talking of the 6fm7 lest the price goes thru the roof....
Old 20th September 2020, 02:36 AM   #35
TOO LATE!!!
$130 for 5 of them (6FM7) at 15% discount on Ebay!
The original 6EM7 look to be cheaper.
Glad I bought a box of them back when they were $1 each (6FM7, 6GF7).
Old 20th September 2020, 06:02 AM   #36
astouffer is offline astouffer  United States
astouffer's Avatar
TOO LATE!!!
I knew it was going to be that bangybang tubes scammer. He sells everything at inflated prices and people fall for it. His listings even show up in places like walmart! Someone has to be laundering money 2 Vintage General Electric 6AL5/6663 Double Diode Detector Tube Valve - BangyBan | eBay
Old 20th September 2020, 06:17 AM   #37
TonyTecson's Avatar
TOO LATE!!!
the 13fm7 was U$1 back then....
Old 20th September 2020, 06:18 AM   #38
TonyTecson's Avatar
whoa.......i got ten of those....
Old 20th September 2020, 07:15 AM   #39
AES (tubesandmore.com) is selling them for 4.9 $ no need to pay inflated prices.
Good luck
Glass painter
Old 20th September 2020, 07:22 AM   #40
Kay Pirinha is online now Kay Pirinha  Germany
Kay Pirinha's Avatar
Who needs 6AL5's, especially at this prize???
Best regards!
"I spent a lot of money on booze, birds and fast cars. The rest I just squandered." (George Best)
Tube amps with tv tubesHide this!Advertise here!
FS: 76 Tubes and pair of Herbies Tube Dampers for 76 tubes carlsor Swap Meet 2 3rd January 2019 03:45 AM
New to tubes and diyaudio here, question about torrids and tube amps... overtheairbroadcast Tubes / Valves 8 13th January 2012 01:16 AM
Tubes,Tube amps, Loudspeakers...You DREAM Here!!!From... nafanja Vendor's Bazaar 36 9th May 2009 11:06 AM
good book for learning the basics of tubes and tube amps frajavcar Tubes / Valves 5 18th July 2008 07:33 PM
wtb books on tubes/tube amps vixr Swap Meet 1 18th February 2006 10:10 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
