KT-88 diagnosis
KT-88 diagnosis
Old 1st August 2020, 07:52 PM   #21
wanders is offline wanders  United States
The project was opened ended, not a defined kit or even bom. I've replaced a couple of caps/resistors with different specs; worked a combinations of power and bias settings; tried different output tubes, etc. Nothing was done to amp1 that wasn't done to amp 2 first; and amp 2 is working fine. I've been planning to install GNFB and wanted everything precisely the same and optimum in both units before I started to experiment with feedback. The risk of tinkering is that you might create a short or knock something loose. I've had that happen a few times, bur was always able to figure it out -- until now.
Old 1st August 2020, 08:30 PM   #22
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Originally Posted by wanders View Post
Must have forgotten to mention the 8 ohm dummy load
Good, I was worried.
That said, an OT "singing" (that is the usual word) is absolutely normal, lamination does exhibit a slight magnetostrictive effect which means they will mechanically vibrate, hence produce *sound* .
Low level, poor efficiency but sound nevertheless.
Tightly pressed laminations or good potting will kill that, a bump may loosen them enough to be audible, even annoying.
But they are a mechanical problems located at or around the OT, you are wasting time by
eliminated the preamp as a cause
testing shorted inputs and eliminating the pre ...... work back through all of the output wiring, checking for broken/cold joints, shorts,
swapped front end tubes and tested with open and shorted input - amp sits quiet. Wavegen input w/o pre: same as with preamp: opt noise and wave deterioration; however the gen does supply about 600 mA.
You mean 600mV?
In any case:
I've eliminated all the suggested alternatives:
does not surprise me, none of those has any relation with your slight problem.
I bet if you vacuum pot your OT "singing" disappears.
Not suggesting you do that, but suggest you live with your very slight problem, which to boot will be inaudible when playing Music through real speakers.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
  Reply to this post
KT-88 diagnosisHide this!Advertise here!
Help confirming a diagnosis Wheelz Car Audio 49 8th January 2020 01:49 PM
Valve amp diagnosis Duke7 Instruments and Amps 5 15th December 2019 08:53 AM
ART DR-X Distortion Help with Diagnosis jwillis44 Instruments and Amps 4 11th December 2016 06:16 PM
Diagnosis please bullpeters Tubes / Valves 19 31st July 2012 06:47 PM
PS Diagnosis? sam9 Solid State 3 1st November 2004 06:59 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
