Questions About This Local NFB Scheme
Old 11th August 2020, 01:24 PM   #61
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Old 11th August 2020, 04:06 PM   #62
20to20 is offline 20to20  United States
Originally Posted by mondogenerator View Post
I'm not sure why there is so much debate over something that has been defined for almost a century.
I don't think there really has been a definition. It's just been assumed local means a shorter loop than global. But if you want to get some terminology better suited for different versions then you could say INTRAstage FB, for plate to plate (which is really plate to grid of the output through its coupling cap) and say INTERstage FB for FB going back to include one or more prior stages but not all stages, and then GFB for a system loop.
Old 11th August 2020, 04:15 PM   #63
jan.didden's Avatar
If you think 'I don't think there is ...' doesn't mean there isn't.
I am again surprised why people want to invent all kinds of terms that nobody else except they understand? Where does this obsessive behavior come from ??
From output to input is global. Everything else is local. What's so hard to understand about that?
It is abundantly clear if you want to see it, that the original title of this thread results from limited understanding of the term 'local feedback'. Local feedback does NOT mean that you return the feedback from output to some 'local' point.
The solution to limited understanding is NOT to invent other terms in an attempt to cover up the limited understanding. Rather, the solution is to read up and Get It.
Jan
Old 11th August 2020, 04:20 PM   #64
That's your definition. Imprecise. Nebulous. Vague.
Old 11th August 2020, 04:44 PM   #65
jan.didden's Avatar
Haha! Is that a trick to let me do your legwork? Will not work, if you are happy with what do or don't know, I'm not going to force you to your happiness.
Jan
Old 11th August 2020, 04:54 PM   #66
kodabmx is offline kodabmx  Canada
Spreading triode love.
kodabmx's Avatar
Originally Posted by GoatGuy View Post
№ 4 — for resistors P = E² / R … = 8² V ÷ 150 = 64 ÷ 150 → 0.43 W. Why the 5 W model? I'm not against it generally, but still … a solid 2 W would be smaller. [/indent]Nothing really matters as long as the P is well below PMAX
⋅-=≡ GoatGuy ✓ ≡=-⋅
Here's a picture of a 3W 47k resistor used as a dropper for an LED. It dissipates 1.5W... It's also in a chassis that is basically an oven. As a rule, I build with the largest resistors practical now! Those 5k6 resistors are series/parallel connected for Pd of 12W with a circuit that needed 2.8W I had them already though, so why not?
Since the burning resistor is just a dropper for an LED, I don't care at all that it's discoloured If it explodes and takes the LED with it, J'men cālice
If you can't learn to do something well, learn how to enjoy doing it poorly.
Old 12th August 2020, 08:16 AM   #67
6A3sUMMER is offline 6A3sUMMER  United States
Take a typical triode:
Use a Regulated grid power supply and a Regulated plate power supply.
Put the grid at -10V.
Put the plate at + 100V.
Put the cathode at 0 Volts
Wait for 1 day for the current to stabilize (are we there yet?).
Then measure the plate current (Ip1)
Put the plate at +200V.
Put the cathode at 0 Volts.
Measure the plate current (Ip2)
200V - 100V = 100V (the change in plate voltage).
Ip2 - Ip1 = Delta Ip (the change in plate current).
100V / Delta Ip = the plate resistance, rp.
Would you call that negative feedback?
After 1 day, the Miller Effect capacitive current is much less than KTB.
Old 12th August 2020, 11:40 AM   #68
Ketje is offline Ketje  Belgium
Ketje's Avatar
Originally Posted by 6A3sUMMER View Post
Take a typical resistance:
Put one end of the resistor at + 100V.
Put the other end at 0 Volts
Then measure the resistor current (Ir1)
Put one end of the resistor at +200V.
Put the other end at 0 Volts.
Measure the resistor current (Ir2)
200V - 100V = 100V (the change in resistor voltage).
Ir2 - Ir1 = Delta Ir (the change in resistor current).
100V / Delta Ir = the resistor resistance, r.
After 1 day, there is no capacitive current, test is done with DC .
Mona
Old 12th August 2020, 12:37 PM   #69
FlaCharlie is offline FlaCharlie  United States
Originally Posted by FlaCharlie View Post
I'm not concerned with semantics so I probably shouldn't have mentioned local vs global thing.
Originally Posted by jan.didden View Post
I am not splitting hairs, it is not about semantics. It is about accurately describing something so that anyone anywhere in the world understands what you mean. Modifying definitions and making them internally inconsistent as well because you have this urge to add something personal to our heritage collapses the community to just you and your buddies. A huge step backward.
I'm not technically astute enough to offer an opinion in the Local vs Global debate. Whatever the correct nomenclature is, I'm enjoying the amp. So thanks to all who helped.
I apologize if my reference to this as Local is hastening the end of civilization as we know it.
Old 12th August 2020, 07:43 PM   #70
Ketje,
Creative!
You "quoted" me, but you changed my words.
I guess that you were saying the triode (rp) was acting just like a resistor.
And, most people will not argue that a resistor has negative feedback.
Thanks!
Questions About This Local NFB SchemeHide this!Advertise here!
Scheme-IT is just what I was looking for... Bas Horneman Software Tools 3 29th July 2013 11:21 AM
regulated PS grounding scheme questions CharlieLaub Power Supplies 7 6th May 2011 05:24 PM
Is this a bad scheme radu8982 Solid State 6 3rd January 2011 11:06 AM
help me on 845 scheme.... blue_angels Tubes / Valves 10 27th October 2004 06:09 AM
tl 084 scheme questions duni Solid State 6 27th March 2004 01:46 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
