Dual 6J5GT can be directly replaced 6SN7?
Thread Tools
Old 6th July 2020, 09:48 AM   #1
supernut is offline supernut  Thailand
Default Dual 6J5GT can be directly replaced 6SN7?
So if project use 2 6J5GT, can I use 1 6SN7 instead?
Old 6th July 2020, 10:01 AM   #2
duncan2 is offline duncan2  United Kingdom
You can even the inter-electrode capacitance's are smaller ( a good thing ) but obviously the bases are different .
All other parameters are identical except the heater current .
Old 6th July 2020, 01:26 PM   #3
Can I do like this? Is it correct?
Old 6th July 2020, 01:56 PM   #4
Yes , the 6SN7 was looked on as an equivalent electrical replacement ( at the time ) for the 6J5 as it saved a tube stage and had near identical specs.
Some might like a whole lot of tubes to light up but you cant argue with identical specifications ( apart from the base and 0.6 heater current ).
Old 7th July 2020, 12:26 AM   #5
6A3sUMMER is offline 6A3sUMMER  United States
2 each 6J5 have a total of 0.6A filament current.
1 each 6SN7 has a total of 0.6A filament current.
It does not get any more equal than that.
(In a circuit with 2 triodes, the heater current is the same).
Old 7th July 2020, 01:45 AM   #6
Thank you very much Duncan2 and 6A3sUMMER
Old 7th July 2020, 01:46 AM   #7
save space of Amplifier chassis by changing 6J5GT to 6SN7
reduce from 2 x 6J5GT to only 1 6SN7
Old 7th July 2020, 11:02 AM   #8
pl802 is offline pl802  United Kingdom
pl802's Avatar
Here you go
r-type.org/exhib/aaa0074.htm
  Reply to this post
Dual 6J5GT can be directly replaced 6SN7?Hide this!Advertise here!
Thread Tools
power tube for 6SN7 for 10 6SN7 in parallel psu rhythmsandy Tubes / Valves 7 5th December 2016 05:49 PM
6SN7/6SN7 Aikido + CS4398 DAC = HEAVEN john65b Tubes / Valves 23 30th April 2014 08:28 PM
6SN7 / 6SN7 Aikido Preamp Board john65b Swap Meet 9 6th March 2013 12:24 PM
can be MJE2955 be replaced??! nbcd Solid State 1 6th November 2003 08:06 PM
How i replaced my dust cap... Vol 1 speekergeek Multi-Way 10 31st October 2003 04:20 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
