Hi, new member, got my hifi mojo back!
Old 28th June 2020, 03:23 PM   #1
brodjack is offline brodjack  United Kingdom
Default Hi, new member, got my hifi mojo back!
hi,got my hifi interest back after about 20yrs,i kept some of my old gear but sadly sold my Klipch horns...and Pink Triangle,sme turntable..
anyway i built a SE 300b amp and stored it in the loft,after removing the valves.
recently got it down and dusted off the thick layers that built up,inside looks fine,but after 20yrs kinda forgot all the specs etc..i built it with help from a Guy called Gary,if i remember,who was from Border patrol,again,if i remember.
It has BP interstage transformers and huge output trans,probably bought from BP,if i remember, and lots of Blackgates,silver wire etc,i spent a fortune on the bits..Looks like it has 2 valve rectified ps's for the interstage tranformers and a modified ps for the main choke input 300b ht,all in seperate enclosures,it weighs a ton..any ideas how i can proceed to get it all running again?
I was pretty good with valves/building when i built it but kinda forgot when i lost interest..
searching for circuits and looks similar to a SJS 108 mk2 amp but mine looks like a 2 stage circuit and didnt write down valves i used,the writing on the valves i kept for it have since lost there numbers so not sure what they were..
Possibly a long shot to sus out what i built but any help appreciated,retired now so lots of spare time to build etc..
Old 28th June 2020, 03:51 PM   #2
korneluk is offline korneluk  United States
korneluk's Avatar
Welcome back!
Please excuse the obvious question, but way back when you built the amp, did you get / follow a schematic?
That would tell you most everything you need know.
Old 28th June 2020, 04:37 PM   #3
yes i did have a schematic but unfortunately lost it may yrs ago in a loft clearout..thanks anyway for the reply..
Old 28th June 2020, 04:56 PM   #4
gerrittube is offline gerrittube  Netherlands
You could upload high resolution pictures from “all” sides (especially the bottom part).
Regards, Gerrit
Old 28th June 2020, 05:02 PM   #5
thanks,up on further inspection it now looks like a 3 stage amplification before the 300b stage..i will take some pics bit later and try to upload them on here..
Old 28th June 2020, 07:22 PM   #6
duncan2 is offline duncan2  United Kingdom
Anything like this ?
BorderPatrol SE300B Stereo Amplifier - The Audio Beat - www.TheAudioBeat.com
Old 28th June 2020, 10:15 PM   #7
possibly based around a BP amp.Wish my memory was better but alot has happened in my life since building it 20yrs ago,but i do remember the superb sound it produced..Struggling posting pics,could be as a new forum member,have another go tomorrow..cheers
Old 29th June 2020, 10:45 AM   #8
few pics,it was built into an old AudioInnovations chassis....
Old 29th June 2020, 02:58 PM   #9
cannext is offline cannext  Netherlands
I spy with my little eye : a wire with its insulation busted /broken .
(3 'd picture coming of the transformer ) .
I do not know where this wire goes but you might want to fix that and see if the other wires are ok .
Regards F.
Old 29th June 2020, 03:34 PM   #10
yes,thought someone would spot it.lol,its may yrs in the loft,20 hot summers and cold winters that perished the insulation,i think..its the wire from the 300b plate to the output tx..think i'm gunna have to strip it down and make a circuit diagram to try identify what valves i used..i would probably re-chassis it anyway if i rebuilt it up..
Hi, new member, got my hifi mojo back!Hide this!Advertise here!
Back into Hifi - Want to go streaming service route (RPi + Roon + DAC) Prolle PC Based 6 5th May 2020 08:19 PM
Mojo 16 4k ian33 Car Audio 9 22nd November 2018 12:17 AM
Mojo fix cyclecamper Instruments and Amps 12 26th March 2013 12:47 AM
Anyone here a member of the German forum "Hifi und Lebensart"? dublin78 Everything Else 7 10th January 2012 01:11 PM
need help with my 12' memphis mojo m3 aphillyated Car Audio 6 25th December 2006 08:54 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
