Introduction and Pentode CF question
Old 26th June 2020, 11:33 AM   #11
EZ80 is offline EZ80  England
Thanks again Mona, I can see now that to use a step down OPT I would have to add gain at least equal to the step down ratio. Could you explain a little more on your comment about also doing balanced input to power amp, this is my reason for wanting TX output. Thanks John
Old 26th June 2020, 01:56 PM   #12
Ketje is offline Ketje  Belgium
Ketje's Avatar
The output of the transformer gives a signal as the difference between the two connections, no relation to ground.
If the amplifier needs a centre (ground) it's the responsability of the amp.
With a transformer input at the amplifier the connection is fully floating.In that case a resistor (>1MΩ) to ground on one of the leads (or a centre tap) to ground is best to prevent charge build-up.
Mona
Old 26th June 2020, 02:06 PM   #13
Thanks again Mona, are you saying I could use the 126b but float the output ? Cheers John
Introduction and Pentode CF questionHide this!Advertise here!
Newbie introduction, quick impedance question... Apfelsauce Multi-Way 13 26th February 2011 06:03 AM
New member introduction & question ianl Tubes / Valves 10 23rd October 2009 05:44 AM
An Introduction and Laney Bass Amp Question Captn Dave Solid State 1 14th June 2009 01:51 PM
A (re)introduction to all, and a specific acoustic center question gtphill Multi-Way 2 19th March 2007 03:31 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
